Struct in a union
Christophe D
Struct in a union
PostPosted: Thu Aug 10, 2006 4:36 am     Reply with quote
Hello there.
I'm having a difficulties with Struct and Union. I would like to create a struct as a member of a union. Here is my code:
#include <18F452.h>
#include "typedefs.h"
#use delay(clock=10000000)
typedef union
int8 _byte;
struct
unsigned bit0:1;
unsigned bit1:1;
unsigned bit2:1;
unsigned bit3:1;
unsigned bit4:1;
unsigned bit5:1;
unsigned bit6:1;
unsigned bit7:1;
} RESPONSE_1;
typedef union
int8 _byte;
struct
unsigned bit0:1;
unsigned bit1:1;
unsigned bit2:1;
unsigned bit3:1;
unsigned bit4:1;
unsigned bit5:1;
unsigned bit6:1;
unsigned bit7:1;
} RESPONSE_2;
int main(void)
RESPONSE_1 response;
response.bit0= 0;
RESPONSE_2 response2;
response2.bit0= 0;
return 1;
The compilers says that bit0 is not a member of "reponse" and "response 2". I'm using PCH version 3.170.
I tested my code in Visual studio and the compiler didn't complain.
Am I doind anything wrong?
Thank in advance.
Christophe D
PostPosted: Thu Aug 10, 2006 6:00 am     Reply with quote
Strange, v3.187 and v3.236 of the compiler give me an error of 'Element is not a member', but version 3.249 compiles without error.
Thing is that I think the older compiler versions are correct and this is an error in v3.249.... maybe it depends on which C standard you are using, K&R or ANSII ?
The way I learned to program this was that you can not have unnamed structs within the union:
typedef union
  int8 _byte;
  struct
    int8 bit0:1;
    int8 bit1:1;
    int8 bit2:1;
    int8 bit3:1;
    int8 bit4:1;
    int8 bit5:1;
    int8 bit6:1;
    int8 bit7:1;
  } MyBits;     // <---  Added a name for the struct
} RESPONSE_1;
void main(void)    // Changed to void, returning a value has no use and is waste of program memory.
  response.MyBits.bit0 = 0;
