PIC18F458 control ServoController(serial) board of parallax
Terk
PostPosted: Wed Aug 09, 2006 9:39 pm     Reply with quote
How to using PIC to control ServoController(serial) board of parallax.
PostPosted: Fri Aug 11, 2006 12:28 pm     Reply with quote
I can't find any board on the Parallax website called a "ServoController".
weetax
Parallax servo controller board website.
PostPosted: Sat Aug 12, 2006 9:11 pm     Reply with quote
http://www.parallax.com/detail.asp?product_id=28023
weetax
PostPosted: Sat Aug 12, 2006 9:17 pm     Reply with quote
It's using serial communication (Open collector).
I'm useing PIC18F458.But parallax board can't response.If i'm using BasicStamp it can be worked. This is my source.
#include <18f458.h>
#define TxD PIN_C6
#define RxD PIN_C7
#fuses H4
#fuses NOLVP, NOWDT
#fuses NOPROTECT
#use delay (clock=40000000)
#use rs232(baud=9600,xmit=TxD,rcv=RxD,stream=pc)
#use rs232(baud=2400,parity=N,xmit=PIN_D0,rcv=PIN_D1,bits=8,stream=psoc,float_high,ERRORS)
#ignore_warnings 202
void INT_Serial(void);
#INT_RDA
void INT_Serial(void){
char c,x,y,z;
long lo,hi,ch,ra;
long data;
c = getc();
switch(c){
case 'a' : fprintf(pc,"pos:1100\n");
data = 1100;
lo = data%255;
hi = data/255;
ch = 0;
ra = 0;
fputc('!',psoc);
fputc('S',psoc);
fputc('C',psoc);
fputc(ch,psoc);
fputc(ra,psoc);
fputc(lo,psoc);
fputc(hi,psoc);
fputc(13,psoc);
case 'b' : fprintf(pc,"pos:500\n");
data = 500;
lo = data%255;
hi = data/255;
ch = 0;
ra = 0;
fputc('!',psoc);
fputc('S',psoc);
fputc('C',psoc);
fputc(ch,psoc);
fputc(ra,psoc);
fputc(lo,psoc);
fputc(hi,psoc);
fputc(13,psoc);
void main(void){
enable_interrupts(INT_RDA);
while(1){
[/quote]
weetax
Success.
PostPosted: Sat Aug 12, 2006 9:39 pm     Reply with quote
OK, I'm can be solve my problem.By change the option of rs232.
#use rs232(baud=2400,xmit=PIN_D0,rcv=PIN_D0,stream=psoc,float_high,ERRORS)
