strange behavior of int32 Array
leto
PostPosted: Tue Aug 08, 2006 4:00 pm     Reply with quote
I have a problem using int32 arrays. I want to load an array each time #int_ext is executed. Then, I print it pressing RB7.
If I use a variable as index as in program below it doesn't work.
   Index=4;
   Values[Index] = 0x1;
it complete Values[3]=65536 instead of Values[4]=1.
but, when I use a numeric index directly is works ok.
   Values[4] = 0x1;
With int8 arrays it works fine. Any suggestions ?
ps. Im using PIC18F452 and CCS 3.249.
thanks
#include <18F452.h>
#device adc=10
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES HS                       //High speed osc with H4 enabled 4X PLL
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOBROWNOUT               //Reset when brownout detected
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#use delay(clock=10000000)
#use rs232(baud=57600, parity=N, bits=8, xmit=PIN_C6, rcv=PIN_C7, errors, stream=SERIAL_PORT)
int32 Values[11];
void Print();
int Index;
#INT_RB
void tecla(void) {
    int step=0;
    delay_ms(20);
    while (!input(PIN_B7)) {
        step+=1;
    if (step >= 5) Print();
#int_ext
void external()
   Index=4;
   printf("Vector  [%d], %lu\r\n",Index,Values[Index]);
void Print()
    int i;
    for(i=0;i<11;i++) {
         printf("Value[%i]=%lu\r\n", i, Values[i]);
// main()
    * Initialization
    setup_psp(PSP_DISABLED);
    setup_wdt(WDT_OFF);
    setup_timer_3(T3_DISABLED);
    setup_low_volt_detect(FALSE);
    setup_oscillator(False);
    port_b_pullups(TRUE);
    ext_int_edge(H_TO_L);
    enable_interrupts(int_ext);
    enable_interrupts(int_rda);
    enable_interrupts(int_rb);
    enable_interrupts(global);
    memset(&Values[0], 0, 44);
    * main loop
PostPosted: Tue Aug 08, 2006 7:00 pm     Reply with quote
Sorry its a mistake. Its a Proteus emulator problem.
