I2c Using 2416EEprom and 16C57
edbfmi1
PostPosted: Mon Aug 07, 2006 2:35 pm     Reply with quote
I am trying to write a simple program to store and retrieve a byte of data to address 1 on an 24LC16B EEprom using a PIC16C57. The idea is to write the value 9 to the EEPROM reset value to 0. Then read the the EEPROM to see if the value read is 9. My simple code is below.
I do have pullups on the SDA and SCL lines.
The program gets into a loop when it does the initial write.
I also have a memory problem that I describe after the code listing below.
//  ---------------------   I2C   ---------------------------------------
#include <16C57.h>
#device *=8,
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=40000000)
#define EEPROM_SDA  PIN_B6
#define EEPROM_SCL  PIN_B7
#include <2416.c>
long int   address;
byte   value;
/* Prototypes */
void main();         /* Main Routine */
void write_eeprom()
   BYTE value;
   EEPROM_ADDRESS address;
   init_ext_eeprom();
   WRITE_EXT_EEPROM( address, value );
void read_eeprom()
   BYTE value;
   init_ext_eeprom();
   value = READ_EXT_EEPROM( address );
   while (1==1)
         address = 1;
         value = 9;
         write_eeprom();
         value = 0;
         read_eeprom();
//         value = 8;
//         write_eeprom();
//         value = 0;
//         read_eeprom();
I planned on doing this again with the value of 8 but of I unremark the the last four lines I get the following when I compile the simple program:
    Error[71] C:\A_TEST\I2C.C 54 : Out of ROM, A segment or the program is too large main
    Seg 00000-001FF, 0125 left, need 01ED
    0000
    Seg 00200-003FF, 0200 left, need 0206
    0000
    Seg 00400-005FF, 0200 left, need 0206
    0000
    Seg 00600-007FF, 0200 left, need 0206
    0000
    Seg 00000-001FF, 0125 left, need 0206
    0000
    1 Errors, 0 Warnings.
With the last four lines remarked out I get the following when it is compiled:
    ROM used: 991 words (48%)
    Largest free fragment is 512
    RAM used: 25 (35%) at main() level
    34 (47%) worst case
    Stack: 1 locations
I am not sure why I use up so much memory with 4 commands?
Any input would be greatfully accepted.
PostPosted: Mon Aug 07, 2006 2:52 pm     Reply with quote
You have set the clock speed to 40 MHz. Max speed allowed is 20 MHz.
This setting must match your crystal value.
This PIC has only 2 stack levels. Sherpa Doug would be the one
with experience in writing CCS code for this type of PIC.
rnielsen
PostPosted: Mon Aug 07, 2006 2:55 pm     Reply with quote
Your code could be longer than you might expect because it also includes 2416.c. You are declaring 'address' and 'value' as global variables and then RE-declare them as local variables inside read_eeprom() and write_eeprom(). Either use Only the global variables and have each function and main() use them or declare them inside of main() and then pass the variables to each function.
Ronald
edbfmi1
PostPosted: Mon Aug 07, 2006 3:05 pm     Reply with quote
I got a little carried away with the "0" it should have been 4Mhz Embarassed
I also made the variables global for this simple program but still no luck Sad
Thanks for the input.
PostPosted: Mon Aug 07, 2006 3:11 pm     Reply with quote
How do you tell if the program is working ? Are you using an ICE ?
edbfmi1
PostPosted: Mon Aug 07, 2006 3:20 pm     Reply with quote
Yes I am using MPLAB v5.7 with the Picmaster in curcuit emulator to watch the values of the registers.
PostPosted: Mon Aug 07, 2006 3:49 pm     Reply with quote
Have you run a very simple program (without EEPROM access) so that
you can prove that the ICE is working ?
PostPosted: Mon Aug 07, 2006 4:05 pm     Reply with quote
Yes,
I have used the ICE to debug a portion of the program that this will be incorporated with. The program multiplexes a 4 digit 7-segment display. All works fine with that part of the program. I removed it for simplicty while I write the next part of the program that stores the data displayed in the EEPROM. I just re-ran the display program again to verify the ICE is working and it worked fine.
edbfmi1
PostPosted: Mon Aug 07, 2006 4:08 pm     Reply with quote
OOPs,
The "guest" reply above was from me. I just got on line at home and forgot to log in before I replied.
