I2C slave problem/USB HID
Borodin
PostPosted: Sun Aug 06, 2006 2:56 pm     Reply with quote
I'm using a i2c master who's sending data to slave address 0x46. I'm using a PIC18F4550 as slave. I put the data and the address I received in hex-format on the screen (hyperTerminal) via RS232. But I also want to put the address and data on the screen with my device configured as a USB HID device.
I tested the USB-module (HID) and it works fine. I changed the report counter in a .h-file from 2 to 4 (for sending 4 bytes to the host). Then I tested the i2c interrupt and it also works fine. But when I put them together in one project, my USB never gets enumerated.
Can anyone tell me if there is a fault, any suggestions ... ?
All comments are welcome.
Thanks.
                      Configuratie, includes en defines
#include <18F4550.h>
#device adc=8
#define __USB_PIC_PERIF__ 1 //interne USB peripheral gebruiken
//instellingen en configuraties
#FUSES NOWDT                    //Geen Watch Dog Timer
#FUSES WDT32768               //Watch Dog Timer Postscale = 1:32768
#FUSES HSPLL                    //High Speed Crystal met PLL ge-enabled
#FUSES NOPROTECT                //Code niet beschermd van lezen
#FUSES NOBROWNOUT               //Geen brownout reset
#FUSES BORV46                   //Brownout reset op 4.6V
#FUSES PUT                      //Power Up Timer
#FUSES NOCPD                    //Geen EE bescherming
#FUSES STVREN                   //Stack full/underflow zal reset veroorzaken
#FUSES NODEBUG                  //Geen Debug mode voor ICD
#FUSES NOLVP                  //Geen Low Voltage Programmeren op pin B5(PIC18)
#FUSES NOWRT                    //Programma geheugen niet schrijf-beveiligd
#FUSES NOWRTD                   //Data EEPROM niet schrijf-beveiligd
#FUSES NOIESO                 //Internal External Switch Over mode disabled
#FUSES NOFCMEN                //Fail-safe clock monitor disabled
#FUSES NOPBADEN               //PORTB pins zijn geconfigureerd als digitale
                              //ingangskanalen bij RESET
#FUSES NOWRTC                   //registers niet schrijf-beveiligd
#FUSES NOWRTB                   //Boot block niet schrijf-beveiligd
#FUSES NOEBTR                   //Geheugen niet lees-beveiligd
#FUSES NOEBTRB                  //Boot block niet lees-beveiligd
#FUSES NOCPB                    //Geen Boot Block code bescherming
#FUSES NOMCLR                 //Master Clear pin disabled
#FUSES LPT1OSC                  //Timer1 geconfigureerd voor low-power werking
#FUSES NOXINST                  //Extended set extensie en ge-indexeerde Addressing
                              //mode disabled (Legacy mode)
#FUSES PLL6                     //24 MHz externe OSC
#FUSES VREGEN                 //USB Voltage Regulator Enable
#FUSES CPUDIV1                //96MHz PLL, divided by 2 for CPU clock
#FUSES USBDIV                 //Clock source from 96 MHz PLL/2
#FUSES NOLPT1OSC              //Timer1 oscillator geconfigureerd voor high power
                              //(low power timer1 osc enable)
#FUSES CCP2B3                 //CCP2 input/output is multiplexed met RB3
#FUSES NOICPRT                //Dedicated in Circuit Debug/Programming enable
#FUSES NOXINST                //Extended Instruction Set disabled
#use delay(clock=48000000)
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#use i2c(Slave,sda=PIN_B0,scl=PIN_B1,address=0x46 ,FORCE_HW)
//include HID handling code.
#DEFINE USB_HID_DEVICE  TRUE
/*de volgede defines zijn nodig om de TX endpoint1 (EP1) te enablen en om buffer-
  ruimte te alloceren.                                                         */
#define USB_EP1_TX_ENABLE  USB_ENABLE_INTERRUPT //IN interrupt transfers voor EP1
#define USB_EP1_TX_SIZE    8  //alloceer 8 bytes in de hardware voor het verzenden
/*de volgede defines zijn nodig om de RX endpoint1 (EP1) te enablen en om buffer-
#define USB_EP1_RX_ENABLE  USB_ENABLE_INTERRUPT //OUT interrupt transfers voor EP1
#define USB_EP1_RX_SIZE    8  //alloceer 8 bytes in de hardware voor het ontvangen
//Microchip 18Fxx5x hardware layer voor usb.c
#include <pic18_usb.h>
//USB configuratie en device descriptors voor dit USB device
#include <usb_desc_hid.h>
//handlet usb setup tokens en get descriptor reports
#include <usb.c>
#DEFINE LED_RUNNING PIN_A3
#DEFINE LED_ISR PIN_A4
#DEFINE LED1 PIN_A2
#define LED_ON output_high
#define LED_OFF output_low
//adresbyte and buffer array definiëren
BYTE address, buffer[10]; //zie interrupt en while-lus
//BYTE incoming, state;
int r = 0;
                                 i²c_interrupt
//enkel adres 0x46 wordt ge-acknoledged, de instelling van meerdere adressen
//geeft uitvoeringsfouten en while lus wordt niet uitgevoerd.
#INT_SSP
void ssp_interupt ()
   BYTE incoming,state;
   state = i2c_isr_state();
   if(state < 0x80)                     //Master is sending data
      incoming = i2c_read();
      if(state == 1)                   //First received byte is address
         address = incoming;
      if(state == 2)                     //Second received byte is data
         buffer[address] = incoming;
   r=1;//zie while-lus
   OUTPUT_HIGH(LED_ISR);
void usb_debug_task(void) {
   static int8 last_connected;
   static int8 last_enumerated;
   int8 new_connected;
   int8 new_enumerated;
   new_connected=usb_attached();
   new_enumerated=usb_enumerated();
   if (new_enumerated)
      LED_ON(LED1);
      LED_OFF(LED1);
   if (new_connected && !last_connected) //USB geconnecteerd, maar nog niet ge-
                                         //enumereerd door de host.
      printf("\r\n\nUSB connected, waiting for enumeration...");
   if (!new_connected && last_connected) //USB nog niet geconnecteerd
      printf("\r\n\nUSB disconnected, waiting for connection...");
   if (new_enumerated && !last_enumerated) //USB werd geënumereerd door de host
      printf("\r\n\nUSB enumerated by PC/HOST");
   if (!new_enumerated && last_enumerated) //nog niet tegengekomen, maar heb het
                                           //wel gedefinieerd.
      printf("\r\n\nUSB unenumerated by PC/HOST, waiting for enumeration...");
   last_connected=new_connected;
   last_enumerated=new_enumerated;
                             main-programma
   int8 out_data[20];   //out: PIC => HOST
   int8 send_timer=0;
   int i = 0;
   BYTE testwaarde = 0x00;
   BYTE testwaarde2 = 0x00;
   LED_ON(LED1);
   usb_init_cs();
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   enable_interrupts(GLOBAL);    //Globale interrupt Call
   enable_interrupts(INT_SSP);   //Interrupt i2c
   setup_low_volt_detect(FALSE);
   setup_oscillator(False);
   printf("\r\n\Running...\r\n");
   OUTPUT_HIGH(LED_RUNNING);
   while (TRUE) //while-lus
      usb_task();
      usb_debug_task();
      if (usb_enumerated())
      OUTPUT_HIGH(PIN_A5);//LED indicates that system is enumerated
         if (r==1) //er is een interrupt geweest
            if (!send_timer)
               send_timer=250;
               //gegevens in de databuffer steken
               out_data[0]=address;
               out_data[1]=buffer[address];
               out_data[2]=testwaarde;
               out_data[3]=testwaarde2;
               //naar buiten brengen via USB en RS232
               if (usb_put_packet(1, out_data, 4 ,USB_DTS_TOGGLE))//4 bytes zenden naar de host
                  printf("\r\n\Address = 0x%X",out_data[0]);
                  printf("\r\n\Buffer[address] = 0x%X",out_data[1]);
                  printf("\r\n\------------------->testwaarde = 0x%X",out_data[2]);
                  printf("\r\n\------------------->testwaarde2 = 0x%X",out_data[3]);
            send_timer--;
            delay_ms(1);
            //OUTPUT_LOW(LED_ISR);
            r=0;
            testwaarde++;
         if (testwaarde == 0xFF)
            testwaarde = 0x00;
            testwaarde2++;
            if (testwaarde2 == 0xFF)
               testwaarde2 = 0x00;
   }//einde van de while lus
}//einde van de main funtie
Borodin
PostPosted: Sun Aug 06, 2006 2:57 pm     Reply with quote
The code isn't coming thru.
Borodin
PostPosted: Sun Aug 06, 2006 3:02 pm     Reply with quote
Thank you for that, PCM programmer.
PostPosted: Sun Aug 06, 2006 3:05 pm     Reply with quote
Edit your post, fix any problems, and then select the checkbox below the
posting window that says "Disable HTML in this post". Then click Submit.
PICoHolic
PostPosted: Fri Apr 27, 2007 2:17 am     Reply with quote
Hello Borodin,
Could you plz tell me under which conditions (FUSES, compiler vesion etc...) it worked fine (I2C Slave) ?
Thank you!
