pwm+pic
pwm+pic
PostPosted: Sun Aug 06, 2006 12:19 pm     Reply with quote
hi
i want to make a 120khz pwm with timer2 of pic16f877a and with 7.67375mhz cristal and duty cycle 50% in ccs software.
please help me
thanks a lot
PostPosted: Sun Aug 06, 2006 2:45 pm     Reply with quote
It'll actually be 119902Hz (you can't quite do 120KHz with the hardware, given your clock frequency), but the required setup lines are:
setup_timer_2(T2_DIV_BY_1,15,1);
setup_ccp1(CCP_PWM);
set_pwm1_duty(32L);
Note the 'L'. This is important, since it makes the code use the extra two bits in the second register for setting the duty cycle.
PostPosted: Mon Aug 07, 2006 11:59 am     Reply with quote
Hi
thanks alot for your guidance.
best regards
Moeini
PostPosted: Tue Aug 08, 2006 1:32 am     Reply with quote
Hi
Kindly please explain for me about numbers in : setup_timer_2(t2_div_by_1,15,1)
and set_pwm1_duty(32L)
Best Regards
PostPosted: Tue Aug 08, 2006 2:35 am     Reply with quote
Get AN564 from Microchip, and learn how the hardware you are trying to use works.
