UDP won't Work
Ashworth
UDP won't Work
PostPosted: Wed May 10, 2006 2:38 am     Reply with quote
I have recently purchased a CCS Embedded Ethernet Development board which has the ENC28J60 on it. Everything was working fine - TCP/IP, HTTP etc until I tried the UDP example. As this is the one I really needed I think I need some Help. I am not an expert C programmer so don't even know if my code is correct. I have removed as much of the Chiff chaff as possible to leave only the code I need. All it should do is to stream out a few bytes to the specified port The LCD display is updating correctly but nothing is actually being transmitted via UDP as far as I can tell.
#define STACK_USE_ICMP  1
#define STACK_USE_ARP   1
#define STACK_USE_UDP   1
#define MAX_SOCKETS                     6//was 6
#define MAX_UDP_SOCKETS                 4//was 4
#include "ccstcpip.h"
#if STACK_USE_CCS_PICENS
 #include "drivers\mlcd.c"
#else
 #include "drivers\dlcd.c"
#define UDP_SOURCE_PORT 61556
#define UDP_DESTINATION_PORT  61557
#define UDP_NUM_LISTEN_SOCKETS   2//was 2
UDP_SOCKET last_rx_socket=INVALID_UDP_SOCKET;
#define tx_socket UDPOpen(UDP_SOURCE_PORT, &UDPSocketInfo[last_rx_socket].remoteNode, UDP_DESTINATION_PORT)
void UDPTxTask(void)
 //  static int8 tx_socket;
   int   Counter;
   char  Char1;
   Counter++;
   Char1=Counter;
//   tx_socket=UDPOpen(UDP_SOURCE_PORT, &UDPSocketInfo[last_rx_socket].remoteNode, UDP_DESTINATION_PORT);
   if (UDPIsPutReady(tx_socket))
      UDPPut("H");
      UDPPut("E");
      UDPPut("L");
      UDPPut("L");
      UDPPut("O");
      UDPPut("\r");
      UDPPut("\n");
     UDPFlush();
 //     UDPClose(tx_socket);
      printf(lcd_putc,"\fVolts :%u",Counter);
void main(void) {
   MACAddrInit();
   IPAddrInit();
   init_user_io();
   lcd_init();
   printf(lcd_putc,"\fUDP Test");
   delay_ms(2000);
   StackInit();
      StackTask();
      UDPTxTask();
 :grin:
PostPosted: Thu May 18, 2006 7:50 am     Reply with quote
Hi ,
The problem is , when you use the CCS example , the fisrt things to do is to receive a packet . When the packet is received by the enc28j60 , the &UDPSocketInfo[last_rx_socket].remoteNode is update and the enc28j60 know the IP adress and the Mac adress
You must know the mac and ip adress. (wiht a arp request , see the TCP example )
Sorry , but my english is bad
Embarassed
Ashworth
How to Trasmit UDP Only then
PostPosted: Thu May 18, 2006 8:30 am     Reply with quote
Thankyou for that information. It makes sense now.
Can you or anyone out there tell me how I just send out UDP packets to a specific port?
Being UDP, I didn't think that you need to know the destination IP only the port number?
I have been using Etherreal and I can see packets appearing, but for some reason its just not being picked up at the other end.
Thanks,
Rob
Alain
PostPosted: Thu May 18, 2006 3:22 pm     Reply with quote
You can see here , one example using UDP.
This is a client , and it try to send string "R/103" to the server "Devicelink" (192.168.0.2). When i know the ip server address , i try to know the mac address of the server to initialised the NODE_INFO DeviceLink (the server)
This work fine Smile
//IP address of the PC running DeviceLink.EXE
IP_ADDR server;
static NODE_INFO DeviceLink;
#define UDP_SOURCE_PORT 2500
#define UDP_DESTINATION_PORT  10000
void UDPTxTask(void) {
   static int8 button;
   static TICKTYPE lastTick;
   static enum {UDP_TX_ARP_INIT=0,UDP_TX_ARP_REQ=1, UDP_TX_ARP_WAIT=2, UDP_TX_OPEN=3, UDP_TX_WAIT=4, UDP_TX_DEBOUNCE=5,
      UDP_TX_ISREADY=6} state=0;
   TICKTYPE currTick;
   int8 dis;
   currTick=TickGet();
   switch (state) {
    case UDP_TX_ARP_INIT:
         memcpy(&DeviceLink.IPAddr, &server, sizeof(IP_ADDR));
         printf(lcd_putc,"\nARP REQUEST     ");
         state=UDP_TX_ARP_REQ;
      case UDP_TX_ARP_REQ:
         if (ARPIsTxReady()) {
            ARPResolve(&DeviceLink.IPAddr);
            lastTick=currTick;
            state=UDP_TX_ARP_WAIT;
      case UDP_TX_ARP_WAIT:
         if (ARPIsResolved(&DeviceLink.IPAddr, &DeviceLink.MACAddr)) {
            state=UDP_TX_WAIT;
            printf(lcd_putc,"\n READY !!   ");
         else if (TickGetDiff(currTick, lastTick) > (TICKS_PER_SECOND * 2)) {
      case UDP_TX_WAIT:
         if (BUTTON1_PRESSED()) {
               state=UDP_TX_DEBOUNCE;
               button=1;
      case UDP_TX_DEBOUNCE:
         if (button==1 && !BUTTON1_PRESSED())
            state=UDP_TX_OPEN;
      case UDP_TX_OPEN:
         tx_socket=UDPOpen(UDP_SOURCE_PORT, &DeviceLink, UDP_DESTINATION_PORT);
         if (tx_socket==INVALID_UDP_SOCKET)
            printf("\r\nCan't open UDP socket for transmit");
            state=UDP_TX_WAIT;
            printf("\r\nStart Transmit UDP BUTTON%U", button);
            state=UDP_TX_ISREADY;
      case UDP_TX_ISREADY:
         if (UDPIsPutReady(tx_socket)) {
            printf(UDPPut, "R/103");
            UDPFlush();
            state=UDP_TX_WAIT;
            printf(lcd_putc,"\n M/A moteur");
void ServerAddrInit(void) {
   //IP address of the PC running TCPSERVER.EXE
   server.v[0]=192;
   server.v[1]=168;
   server.v[2]=0;
   server.v[3]=2;
void main(void) {
   MACAddrInit();
   IPAddrInit();
   init_user_io();
   lcd_init();
   printf(lcd_putc,"\f DEVICELINK\nPacific Fighter");
   ServerAddrInit();
   StackInit();
   while(TRUE) {
      StackTask();
      UDPTxTask();
     // UDPRxTask();
Ashworth
UDP Success
PostPosted: Wed Jun 07, 2006 4:08 am     Reply with quote
Thanks,
Sorry for late reply, but that works excellent. I tihk the problem was just that I wasn't specifing a destination IP.
Don't know how their example could ever work.
Thanks,
Rob
Ricardo
Can you post all code for me??
PostPosted: Fri Aug 04, 2006 4:54 pm     Reply with quote
Something is wrong here.
Cannot connect to my enc28j60.
Can you send your example and all files dependences, i´m trying to make in my
Send to pozza@tropicalclube.com.br
Sory bad english
thientaisodo
PostPosted: Sat Aug 30, 2014 12:27 pm     Reply with quote
IP_ADDR server;
   static int8 button;
   TICKTYPE currTick;
   int8 dis;
   currTick=TickGet();
   switch (state) {
            lastTick=currTick;
            state=UDP_TX_WAIT;
      case UDP_TX_WAIT:
               button=1;
            state=UDP_TX_OPEN;
      case UDP_TX_OPEN:
            state=UDP_TX_WAIT;
            UDPFlush();
            state=UDP_TX_WAIT;
   server.v[0]=192;
   server.v[1]=168;
   server.v[2]=0;
   server.v[3]=2;
void main(void) {
   MACAddrInit();
   IPAddrInit();
   init_user_io();
   lcd_init();
   ServerAddrInit();
   StackInit();
   while(TRUE) {
      StackTask();
      UDPTxTask();
     // UDPRxTask();
Hi @Alain !
Thanks for your UDPTxTask(), it's work very fine with me.
But i trouble with UDPRxTask(). It not work.
I'm using UDP_SOURCE_PORT 6666 and UDP_DESTINATION_PORT 6666 too for UDP transceive.
Please help me :(
void UDPRxTask(void)
   char  c;
   TICKTYPE currTick;
   currTick=TickGet();
   if (g_UDPRXSocket == INVALID_UDP_SOCKET)
      g_UDPRXSocket = UDPOpen(UDP_SOURCE_PORT,NULL,INVALID_UDP_SOCKET);
   else if (UDPIsGetReady(g_UDPRXSocket))
      UDPGet(&c);
      enable_print_ip=0;
      printf(lcd_putchar,"UDP Received: %c            ",c);
      UDPDiscard();
