arunb
How to determine if a function exceeds a page limit ?? |
Posted: Fri Aug 04, 2006 3:30 am |
How can one determine whether a function exceeds the page limt ??
thanks
arunb |
rnielsen
Posted: Fri Aug 04, 2006 8:19 am |
Well, I check it out by clicking on the compile button and if I get an error message that I'm out of memory then I know that something was too big.
Ronald |
arunb
RE: |
Posted: Fri Aug 04, 2006 9:35 am |
I was refering to the size of a function and not the program size (if the program exceeds the ROM size , then 'Out of ROM ' error occurs)
When a function becomes very large , the mcu starts to go haywire, one way to check this out is to run the mcu, but I think there should be another way....
thanks
arunb
[/code] |
rnielsen
Posted: Fri Aug 04, 2006 10:59 am |
The PIC should run just fine regardless of the size of the routines you call. If any of the routines are to large to fit into a page then the compiler will tell you, otherwise they should work just fine. I've had routines that barely squeeze into a page. I'm not sure what might be going on. Maybe check your LST file and see what the stats are for Stack. Too many and you'll choke.
Ronald |
arunb
RE: |
Posted: Fri Aug 04, 2006 11:05 am |
PCM 3.228
MCU:16F877A
Thank you for the reply.
The stack looks OK (less than 7)
Here is an extract of the .LST file, coould you tell me what is wrong with this
Quote: |
CCS PCM C Compiler, Version 3.228, 16542 02-Aug-06 21:03
Filename: CLG004Main-v2.LST
ROM used: 2121 words (26%)
Largest free fragment is 2048
RAM used: 61 (35%) at main() level
71 (41%) worst case
Stack: 5 worst case (3 in main + 2 for interrupts)
I find that whenver then ROM used is more than Largest free fragment, the mcu goes haywire, as in this case.
Kindly advise ...
thanks
arunb |
