da21
suppress leading zero's on lcd |
Posted: Fri Aug 04, 2006 8:46 am |
Hi all ,
i am trying to suppress leading zero's on a thermometer application using a standard LCD display , i thought this should work but i get a
'constant out of the valid range ' -16 is not 0..255 error
i am sure i have used this on an older version of the compiler before
boolean zero;
if (!num && zero) // blank zero's if previous was zero
num = ' ' - '0'; ?? error on this line
any idea of a fix |
Posted: Fri Aug 04, 2006 9:14 am |
Surely, if you just want to blank the digit, the line wants to just read:
num=' ';
As it stands, you are taking ASCII 'space' (=32), and subtracting ASCII '0' (=48).
If you do want to put '-16' into the num value, you can do it with:
num=(int8)(' '-'0');
It'll actually be stored as '0xF0', which will behave like -16, if arithmetic is performed on it (add 16 to get 0 etc.).
