Converting hex to decimal
Fabri
PostPosted: Thu Jul 27, 2006 11:03 am     Reply with quote
Hi everybody,
I need to convert hex into decimal number 3 digit as show:
int16 hexnumber;
char string[4];
sprintf(string,"%03Ld",hexnumber);
digit1=0x0f & string[0];
digit2=0x0f & string[1];
digit3=0x0f & string[2];
Sometime in string[0] there's an incorrect value for example 0x46 instead 0x30.
Somebody can help me ?
Regards,
rnielsen
PostPosted: Thu Jul 27, 2006 11:13 am     Reply with quote
How are you declaring digit1 through digit3? You do not need the leading zero(0) in the sprintf() command to get three places inserted into string. How are you finding out (another printf() command?) what has been inserted into digit1 through digit3? A little more info might let us see how you are formatting everything.
Ronald
Fabri
PostPosted: Fri Jul 28, 2006 2:17 am     Reply with quote
Hi rnielsen,
I declared digit1 to digit3 as integer and are only result of conversion from string to digit. In debug the variable hexnumber is ok before sprintf. No more sprintf is used in the project.
what are you meaning with:
If I declare:
char string[6];
Is there any difference in result of sprintf ?
I'm using compiler PCWH V.3,235 and PIC16F690
Thanks for help,
PostPosted: Fri Jul 28, 2006 2:44 am     Reply with quote
How is the value put 'into' 'hexnumber'?.
What you post will fail (nastily), if hexnumber goes >999, since then the string will overflow the storage space available. Also if the source value, is actually _signed_, and then gets transferred into the 'unsigned' hexnumber, you will get probelms.
Add a test where you load 'hexnumber'. Something like:
//assuming incoming value is called 'source'.
if (source<0>999) hexnumber=999;
else hexnumber=source;
and see if this makes things work as you expect.
Fabri
PostPosted: Fri Jul 28, 2006 3:08 am     Reply with quote
Hi Ttelmah,
The value into hexnumber is 0 to 400 and there's no possibility to have number excedeed 999.
For example hexnunber is 0x3A (58 decimal) and normally string is 0x30 0x35 0x38 0x00 (digit=058).
Sometimes hexnumber is 0x3A but string after convertion is 0x30 0x73 0x38 0x00.
This happend in case I declared:
char string[6];
instead of
char string[4];
By your side does it possible and is this the problem ?
Thanks,
Eugeneo
Re: Converting hex to decimal
PostPosted: Fri Jul 28, 2006 4:50 am     Reply with quote
When you say hex, do you mean bcd?
PostPosted: Fri Jul 28, 2006 4:51 am     Reply with quote
The simple answer I'm afraid, is that something else is causing your problem. Possibilities are:
An interrupt handler, that does not save all the registers, resulting in an incorrect array index, or value.
Another part of the code overwriting a value.
A value that is not as you expect.
A pointer being used, that points to a value that is not retained (remember if you return values 'from' a routine, using a pointer, and these are declared as 'transient' values - not global, or static, then these can be destroyed once the routine exits).
Any one of perhaps a dozen other similar faults...
Now I am pretty confident of this, for a simple reason. I generated the following 'test' program, compiled it with 3.235, loaded it into a hardware ICU, and left it running for 20 minutes. Not a single failure...
#include "C:\Program Files\PICC\amtest\testprint.h"
#use rs232(baud=9600,parity=N,xmit=PIN_B7,rcv=PIN_B5,bits=8,ERRORS)
char string[6];
int8 digit1,digit2,digit3;
void splitdigits(int16 val) {
   sprintf(string,"%03ld",val);
   digit1=string[0] & 0xf;
   digit2=string[1] & 0xf;
   digit3=string[2] & 0xf;
   int16 ctr;
   int8 temp;
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_oscillator(False);
   while (true) {
      for (ctr=0;ctr<400;ctr++) {
         splitdigits(ctr);
         temp=ctr/10;
         temp=temp%10;
         //Temp should equal the second digit here
         if (temp!=digit2) {
            printf("ERROR/n");
