out ascii on port b
hadeelqasaimeh
out ascii on port b
PostPosted: Wed Jul 26, 2006 12:24 am     Reply with quote
hi all
i need to out charachters on portb and recieve them on other pic (both are 16f874) but its dosent work,,,here is the TX code
#include <16F877a>
#include "string.h"
#include "lcd_kbd1.c"
#fuses XT,NOWDT,NOPROTECT
#byte tris_b =0x00
int f;
int value;
static char MX[6];
   strcpy(MX,"1");
   output_b(0x00);
   //value=0x25;
   delay_ms(2000);
   output_b (MX);
}//while(true)
}//main
and here is the RX code
#include <16F877a>
#include "string.h"
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#byte tris_b =0xff
static char RX[15];
int1 f;
int8 i,value;
   f=0;
   LCD_Init();
while(TRUE) {
//if(f==1) {
   value=input_b();
   LCD_PutCmd ( CLEAR_DISP );
   LCD_SetPosition ( LINE_16_1);
   printf(LCD_PutChar,"RX is");
   LCD_SetPosition ( LINE_16_2);
   printf(LCD_PutChar,"     %d",value);
}//while
thanx alot
PostPosted: Wed Jul 26, 2006 2:47 am     Reply with quote
There is nothing to synchronise the transactions. You cannot be sure when the PICs actually start, and if one leads the other by a small amount of time, the data will always be corrupted. This is why 'asynchronous' communications (like RS232), have a 'start' bit, to mark where the transaction starts. Seperately, what you are actually 'sending', is the low byte of the address where the array is stored, not the array contents...
Do something like this:
//TX
//Need processor setup etc., here.
char MX[6];
//You do not need the static declaration for a 'global'.
void main(void)  {
   int8 ctr;
   strcpy(MX,"1234");
   while (TRUE) {
       //output a 'marker'
       output_b(0xAA);
       delay_ms(1);
       //Now switch to the 'start of transmission' marker
       output_b(0x55);
       for (ctr=0;ctr<6;ctr++) {
          //Now send the characters
          output_b (MX[ctr]);
          delay_ms(1);
       } //for
       output_b(0);
       //ensure we are not sending the 'marker' bytes
    } //while
}//main
//RX
char RX[6]; //Only needs to be the same size as the TX buffer
void main(void) {
   int8 ctr;
   //On _both_chips, you should add any code to turn off things like
   //the adc here.
   LCD_Init();
   while(TRUE) {
      while (input_b() != 0x55);
      //wait for the first marker
      while (input_b() == 0x55);
      //Now the main code is moving to start sending the data
      delay_us(500);
      //delay long enough for the first byte to be present.
           //get the bytes at 1mSec pacing
           RX[ctr]=input_b();
           delay_ms(1);
      }//for
      //At this point the 'transaction' has been received
      printf(LCD_PutChar,"     %s",RX);
      //No delay here, need to get back, and start waiting for the next
      //message.
   }//while
}//main
The key is that the receiver waits till it sees the 'AA' character, and then waits for this to change. At this moment, the transmitter will start sending a few uSec latter (the time it takes to setup the counter, and access the array), and will send the characters at just over 1mSec intervals. The receiver waits 500uSec, so the first character should have arrived, and then reads six characters at the same basic pacing. Any slight errors in the timings of the two loops, willbe handled by the fact that we should be just about in the 'middle' of the character time.
rnielsen
PostPosted: Wed Jul 26, 2006 10:01 am     Reply with quote
It appears that you might be trying to communicate similar to a parallel port. You would need to have a Strobe signal, from the TX PIC, to tell the RX PIC when to look at it's port. Probably hook it up to an interrupt pin would work.
Ronald
