Can a 16bit (Nx8bit) variable be returned?
Goto page 1, 2  Next
eager
PostPosted: Sun Jul 23, 2006 11:44 am     Reply with quote
Hello.
Is it possible to return a 16bit value?
unsigned int16 variable = 12345;
unsigned int16 some_other_variable;
void main(void){
some_other_variable = my_function();
unsigned int16 my_function(void){
return variable;
Thank you!
Mark
PostPosted: Sun Jul 23, 2006 12:26 pm     Reply with quote
Of course!
eager
PostPosted: Sun Jul 23, 2006 2:26 pm     Reply with quote
I suspected this would be the answer. Now I have to figure out why it doesn't work in my case. Confused
eager
PostPosted: Sun Jul 23, 2006 2:48 pm     Reply with quote
Forgot the code... Hope it will be posted in one piece.
unsigned int16 voltage(void){
unsigned char i;
unsigned int16 voltage_16bit;
measure16bit=0x0000;
voltage_sum = 0x0000;
voltage_ = 0x0000;
voltage_max = 0x0000;
voltage_min = 0xFFFF;
for(i=0;i<66;i++){
GO=1;
while(ADCON0&0x04){}
voltage_16bit = ADRESH;
voltage_16bit = voltage_16bit <<8> voltage_max) voltage_max = voltage_16bit;
if(voltage_16bit <voltage_min>> 6;
measure16bit = voltage_;
return voltage_;
As I return the value of voltage_ to a 16bit variable it gets only the first 8bits. Rolling Eyes
PostPosted: Sun Jul 23, 2006 5:18 pm     Reply with quote
You never define voltage_
At least you don't show it in your code.
Also, ending a variable with _ is kinda dumb. It only decreases readability and its not like your going to use 'voltage' and 'voltage_'. So leave off the _, otherwise you'll confuse yourself. I've used _ at the start of a variable before if its a number like _4XR, but I only do that when I can't think of a better variable name.
PostPosted: Mon Jul 24, 2006 2:56 am     Reply with quote
Making a few comments.
First, use the 'code' button to post code. It retains the indentation, and makes it much easier to read.
Second, the line after reading ADRESH, is garbage.
Third, the next line is too...
Fourth, how would you ever expect it to get more than 8bits of data. You never read the ADRESL register.
Mark
PostPosted: Mon Jul 24, 2006 7:47 am     Reply with quote
I assumed this was screwed up because HTML is turned on. In any case, it looked like garbage so I didn't even look at it.
eager
PostPosted: Mon Jul 24, 2006 12:35 pm     Reply with quote
Hello.
I am sorry for the scrambled code. I was not a registered user when I posted and I could not edit nor delete that messed up post. For some reason I was also unable to register. Got a "over quota" or something like that message.
For comments regarding the _ in the name of the variable: it works for me. And that's all that matters.
Here is the code that does not pass all the 16 bits. Let me add I doublechecked that I pass it to a 16bit variable.
//voltage_ is a global variable defined elsewhere, measure16bit
// is a global variable used elswhere
unsigned char i;
voltage_ = 0x0000;
for(i=0;i<66;i++){
GO=1;
voltage_16bit = voltage_16bit << 8;
voltage_16bit = voltage_16bit | ADRESL;
voltage_sum=voltage_sum + voltage_16bit;
if(voltage_16bit > voltage_max) voltage_max = voltage_16bit;
if(voltage_16bit < voltage_min) voltage_min = voltage_16bit;
voltage_ = voltage_sum - voltage_max - voltage_min;
voltage_ = voltage_ >> 6;      //6bit right divide by 64
measure16bit = voltage_;      //10bit for the LCD
return voltage_;
Best regards and thank you.
Mark
PostPosted: Mon Jul 24, 2006 12:42 pm     Reply with quote
Where are the definitions for voltage_ , voltage_sum, voltage_min, and voltage_max?
eager
PostPosted: Mon Jul 24, 2006 12:56 pm     Reply with quote
Also global, forgot to mention it, sorry. Embarassed
Best regards.
Mark
PostPosted: Mon Jul 24, 2006 1:17 pm     Reply with quote
And again your forgot to show them! I want to see where you declared them
eager
PostPosted: Mon Jul 24, 2006 1:32 pm     Reply with quote
It looks a little bit like this:
#include <the MCU.h>
#fuses
pin definitions etc.
//function defined
unsigned int16 voltage(void);
//variables defined
unsigned int16 voltage_sum;
unsigned int16 voltage_;
unsigned int16 voltage_max;
unsigned int16 voltage_min;
unsigned int16 measure16bit;
void main(void){
      while(1){
             some_other_variable = voltage();
unsigned char i;
voltage_ = 0x0000;
for(i=0;i<66;i++){
GO=1;
return voltage_;
Is that what were you looking for?
Best regards.
Mark
PostPosted: Mon Jul 24, 2006 2:22 pm     Reply with quote
#include <16F876>
//function defined
//variables defined
#byte ADRESH = 0x1E
#byte ADRESL = 0x9E
#byte ADCON0 = 0x1F
#bit GO = ADCON0.2
  unsigned char i;
  voltage_ = 0x0000;
  for(i=0;i<66;i++)
    GO=1;
    while(ADCON0&0x04)
    ADRESH = 0x02;
    ADRESL = 0x45;
  return voltage_;
  setup_adc_ports (ALL_ANALOG);
  setup_adc (ADC_CLOCK_INTERNAL);
  set_adc_channel(0);
This works just fine. Maybe its your ADC.
eager
PostPosted: Mon Jul 24, 2006 2:36 pm     Reply with quote
Well, I think everyting is ok with the code too. The only difference between your code and mine is that I use the next bigger MCU and I defined the registers (#byte) in a *.h file which I include right after the MCU.h file. I really do not understand where did I f* up. The intresting thing is that the code fails to perform in MPLABSIM too. Strange. Confused
Best regards.
PostPosted: Mon Jul 24, 2006 3:37 pm     Reply with quote
The obvious comment, is 'maths overflow'. You are doing a 0 to 65 _inclusive_ loop. 66 samples. Each sample can be up to 1023 in value. 1023 * 66 = 67518. Too large to fit in an int16. You can only sum a maximum of 64*10 bit values in a int16.
Second comment. You seem to be trying to 'simulate', by writing to the ADRES registers. This won't work. The registers behave as a _pair_, and should really be treated as read only. In fact you can write to them, but writing to the low register wll clear the high register. I suspect this is why you are seeing an 8bit value...
Goto page 1, 2  Next
Page 1 of 2
