Port status
Port status
PostPosted: Mon Jul 24, 2006 7:07 am     Reply with quote
Hello everyone !
I had a look on the forum before asking but I've got to many replies and they were not dealing with my problem.
Actually, it's quite simple : I would like to know the state of each PIN of one Port. Let say I'm using pin B0 to B3 of PortB. Each pin is connected to a button. When you press the button, the pin status changes from high to low. I would like to know the state (high or low) of the 4 pins I've mentioned, without using interrupts, approximately like this :
   //port_b_pullups(TRUE);
   setup_adc_ports(NO_ANALOGS|VSS_VDD); //Entrées/Sorties en digital
   setup_adc(ADC_OFF|ADC_TAD_MUL_0); //On n'utilise pas l'ADC
   setup_spi(FALSE); //Pas de communication SPI
   setup_wdt(WDT_OFF); //Pas de Watchdog timer
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_1,255,1);
   setup_vref(FALSE);
   setup_low_volt_detect(FALSE);
   setup_oscillator(FALSE);
   //Configuration des ports du microcontrôleur
   SET_TRIS_A(0x80); //Configuration du port A : A7 en entrée, le reste en sortie
   SET_TRIS_B(0x0F); //Configuration du port B = écran LCD et LEDS Tout en sortie
   SET_TRIS_C(0x80); //Configuration du port C : C7 en entrée, le reste en sortie
   while(TRUE) //Infinite loop
   //TEST
   //Something like :
   // if(PIN_B0==1) { ...}
   // or
   // if(output_bit(PIN_B0,1)==TRUE) { ]
   // but none of this work.
I don't see why we could face difficulties knowing the pins' state.
Have a nice day all.
birumher
PostPosted: Mon Jul 24, 2006 7:33 am     Reply with quote
try
if (INPUT(PIN_B0) == 0)
rwyoung
PostPosted: Mon Jul 24, 2006 7:48 am     Reply with quote
Per the November 2005 PDF manual (your page numbers may be different, consult the index of your copy):
INPUT() page 119
INPUT_x() page 121
BIT_TEST() page 92 (with some "gymnastics")
#byte and #bit pages 34 and 35
Several example programs are cited on these pages for your reference.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Mon Jul 24, 2006 7:56 am     Reply with quote
I have gotten used to not using CCS's functions for reading port pins' status.
#byte port_b=0xf81  // on a picf18f458, 0xF81 is the address of PORT B
unsigned char x;
x = port_b;  // this reads port_b
In assembly, one would read port b as:
movf PORTB,w
movwf TEMPX
If you stop relying on a compiler's functions, and instead try to understand the assembly, then writing it in C would be a no-brainer.
AcquaVx
PostPosted: Mon Jul 24, 2006 8:11 am     Reply with quote
Thank you for the advice. I've used birumher's method and it's working fine.
You're right MikeValencia, I'll try to keep it in mind.
A great afternoon.
MikeValencia
PostPosted: Mon Jul 24, 2006 9:56 am     Reply with quote
By the way, here is how you would code it using the #byte method:
    while (1)
        if (PORT_B & 0x01) // Is PortB Bit 0 equal to '1'?  0000 0001
            // do what you want here
If you want to test if it is equal to '0':
    if ( !(PORT_B & 0x01)) // Is PORTB Bit 0 equal to '0'? 0000 0010
Or if you want to test if PORTB Bit 1 is equal to '1'
    if (PORT_B & 0x02)  // Is PORTB BIT 1 equal to '1'?  0000 0010
