Download Hex data from PC
thushi
PostPosted: Mon Jul 24, 2006 5:21 am     Reply with quote
Hi all,
I am using PIC16F877A, PIC C compiler to generate "Bell" sound. In order to do that I want to download data from PC to PIC16F877A flash memory. How can I do that? My data is stored in a column and saved in a text file. Can you please help me? (with source code if possible!)
Thank you
John Morley
PostPosted: Mon Jul 24, 2006 12:36 pm     Reply with quote
You could transmit the data to the PIC over an RS-232 interface. Thus, your problem is two-fold. First, you need a small program running on the PC (written using VB perhaps?) to read your text file line-by-line and send each byte to the PC serial port. Then you need to write code for the PIC to receive the data byte-by-byte and store it in the Flash memory. Overall, a relatively simple project, but a really a lot to deal with if you are a beginner.
John Morley
skel
Any links?
PostPosted: Mon Jul 24, 2006 5:26 pm     Reply with quote
Good response bro'.
Do you have some links where I can do more reading on?
John Morley
PostPosted: Mon Jul 24, 2006 9:46 pm     Reply with quote
I'd start with Google and do a search on "VB6 MSCOMM". This will provide you with lots of useful information on using VB6 to access the PC serial port. Next, I'd search this forum for "RS232" and "Int_RDA", etc. to learn about using the PIC serial port with CCS C. That should give you a good start.
John Morley
