Highwind
DS1307 RTC and 24LC256 EEPROM on the same i2c bus problem |
Posted: Mon Jul 24, 2006 2:13 am |
Hello!!
I use DS1307 and 24LC256 on the same bus and it have some problem.
When i use DS1307 alone its work well
But when i connect 24LC256 on the bus the time i get from DS1307 always be 45:85:85
any suggestion?
my pic is 16f877 using PIN_C3 as SCL and PIN_C4 as SDL.
I have 10k resistor pull up to +5V on both pins.(try change this to 1k but same thing) |
birumher
Posted: Mon Jul 24, 2006 2:37 am |
I use DS1307 and 24LC32 on the same bus and it works fine.
Here is my circuit
and here is the code.
#if defined(__PCM__)
#include <16F877>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#elif defined(__PCH__)
#include <18F452>
#fuses XT,NOWDT,NOPROTECT,NOLVP,NOPUT,NOBROWNOUT
#endif
#define RTC_SDA PIN_C4
#define RTC_SCL PIN_C3
#define EEPROM_SDA PIN_C4
#define EEPROM_SCL PIN_C3
#use i2c(master, sda=RTC_SDA, scl=RTC_SCL, FORCE_HW)
#include <lcd>
#include "ds1307.c"
#include <2432>
BYTE data;
BYTE data2;
long int addr;
init_ext_eeprom();
lcd_gotoxy(1,1);
data = 12;
data2 = 12;
addr=5;
// write 12 to 5. byte
write_ext_eeprom(addr, data);
printf(lcd_putc,"write ad.\%02Lu data \%02u", addr, data);
delay_ms(40);
while (1)
lcd_gotoxy(1,2);
// read 5. byte
data2 = read_ext_eeprom(addr);
lcd_gotoxy(1,2);
printf(lcd_putc,"read ad.\%02Lu data \%02u", addr, data2);
you have to replace #include <2432> with #include <24256>
and here is DS1307.C
/// DS1307.C ///
/// Driver for Real Time Clock ///
/// ds1307_init() - Enable oscillator without clearing the seconds register -///
/// used when PIC loses power and DS1307 run from 3V BAT ///
/// - Disable squarewave output ///
/// ds1307_set_date_time(day,mth,year,dow,hour,min,sec) Set the date/time ///
/// ds1307_get_date(day,mth,year,dow) Get the date ///
/// ds1307_get_time(hr,min,sec) Get the time ///
//#define RTC_SDA PIN_C4
//#define RTC_SCL PIN_C3
//#use i2c(master, sda=RTC_SDA, scl=RTC_SCL, FORCE_HW)
BYTE bin2bcd(BYTE binary_value);
BYTE bcd2bin(BYTE bcd_value);
void ds1307_init(void)
BYTE seconds = 0;
i2c_start();
i2c_write(0xD0); // WR to RTC
i2c_write(0x00); // REG 0
i2c_start();
i2c_write(0xD1); // RD from RTC
seconds = bcd2bin(i2c_read(0)); // Read current "seconds" in DS1307
i2c_stop();
seconds &= 0x7F;
delay_us(3);
i2c_start();
i2c_write(bin2bcd(seconds)); // Start oscillator with current "seconds value
i2c_start();
i2c_write(0x07); // Control Register
i2c_write(0x80); // Disable squarewave output pin
i2c_stop();
void ds1307_set_date_time(BYTE day, BYTE mth, BYTE year, BYTE dow, BYTE hr, BYTE min, BYTE sec)
sec &= 0x7F;
hr &= 0x3F;
i2c_start();
i2c_write(0xD0); // I2C write address
i2c_write(0x00); // Start at REG 0 - Seconds
i2c_write(bin2bcd(sec)); // REG 0
i2c_write(bin2bcd(min)); // REG 1
i2c_write(bin2bcd(hr)); // REG 2
i2c_write(bin2bcd(dow)); // REG 3
i2c_write(bin2bcd(day)); // REG 4
i2c_write(bin2bcd(mth)); // REG 5
i2c_write(bin2bcd(year)); // REG 6
i2c_write(0x80); // REG 7 - Disable squarewave output pin
i2c_stop();
void ds1307_get_date(BYTE &day, BYTE &mth, BYTE &year, BYTE &dow)
i2c_start();
i2c_write(0xD0);
i2c_write(0x03); // Start at REG 3 - Day of week
i2c_start();
i2c_write(0xD1);
dow = bcd2bin(i2c_read() & 0x7f); // REG 3
day = bcd2bin(i2c_read() & 0x3f); // REG 4
mth = bcd2bin(i2c_read() & 0x1f); // REG 5
year = bcd2bin(i2c_read(0)); // REG 6
i2c_stop();
void ds1307_get_time(BYTE &hr, BYTE &min, BYTE &sec)
i2c_start();
i2c_write(0xD0);
i2c_start();
i2c_write(0xD1);
sec = bcd2bin(i2c_read() & 0x7f);
min = bcd2bin(i2c_read() & 0x7f);
hr = bcd2bin(i2c_read(0) & 0x3f);
i2c_stop();
BYTE temp;
BYTE retval;
temp = binary_value;
retval = 0;
// Get the tens digit by doing multiple subtraction
// of 10 from the binary value.
if(temp >= 10)
temp -= 10;
retval += 0x10;
else // Get the ones digit by adding the remainder.
retval += temp;
return(retval);
// Input range - 00 to 99.
BYTE temp;
temp = bcd_value;
// Shifting upper digit right by 1 is same as multiplying by 8.
temp >>= 1;
// Isolate the bits for the upper digit.
temp &= 0x78;
// Now return: (Tens * 8) + (Tens * 2) + Ones
return(temp + (temp >> 2) + (bcd_value & 0x0f));
Highwind
Posted: Mon Jul 24, 2006 3:29 am |
this is my code
Code: | #include <16F877>
#device *=16
#fuses XT,NOWDT,NOLVP
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7)
#byte port_a = 0x05
#byte port_d = 0x08
#include <lcds>
#include <24256>
#include <ds1307>
BYTE sec;
BYTE min;
BYTE hrs;
BYTE day;
BYTE month;
BYTE yr;
BYTE dow;
#int_RDA
RDA_isr() {
void main() {
int data;
port_b_pullups(TRUE);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(FALSE);
setup_psp(PSP_DISABLED);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
enable_interrupts(INT_RDA);
enable_interrupts(global);
set_tris_a(0x00);
set_tris_d(0x00);
port_a = 0x00;
port_d = 0x00;
data = 0x00;
ds1307_init();
init_ext_eeprom();
lcd_putc("\f Test I2C \n");
//write_ext_eeprom(0x0005,0x32);
ds1307_set_date_time(23,7,6,1,18,47,00);
ds1307_get_time(hrs,min,sec);
lcd_putc("\f Time:");
lcd_putc((hrs/10) + 0x30);
lcd_putc((hrs%10) + 0x30);
lcd_putc(':');
lcd_putc((min/10) + 0x30);
lcd_putc((min%10) + 0x30);
lcd_putc(':');
lcd_putc((sec/10) + 0x30);
lcd_putc((sec%10) + 0x30);
lcd_putc(" \n");
//data = read_ext_eeprom(0x0005);
//lcd_putc("data = ");
//lcd_putc((data/10)+0x30);
//lcd_putc((data%10)+0x30);
and I use DS1307.c the same as your
DS1307 alone is fine but when 24LC256 is connect it keep reading 45:85:85
if i have //write_ext_eeprom(0x0005,0x32); program will hang and LCD keep showing "Test I2C" |
birumher
Posted: Mon Jul 24, 2006 7:21 am |
in 24256.c pins are
#ifndef EEPROM_SDA
#define EEPROM_SDA PIN_B1
#define EEPROM_SCL PIN_B0
#endif
you have to change it...
And in your circuit A0, A1, A2 of 24256 must be grounded. Check it.
And did you try only 24LC256 without DS1307 in the circuit? |
