16f628, internal oscillator, and rb5/mclr ...
Calamar
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Thu Jul 24, 2003 8:03 pm     Reply with quote
How is it possible to choise from 4MHZ or 32.768Hz internal osilator ??
What should I do to set pin 4 as reset pin and one more time
as input port and one more time as reset port and ....
thank in advance....
___________________________
Original Post ID: 144516336
Best Regards
Daniel H. Sagarra
La Plata (Argentina)
Re: 16f628, internal oscillator, and rb5/mclr ...
PostPosted: Fri Jul 25, 2003 12:57 pm     Reply with quote
:=How is it possible to choise from 4MHZ or 32.768Hz internal osilator ??
:=What should I do to set pin 4 as reset pin and one more time
:=as input port and one more time as reset port and ....
These settings are done with the #fuses statement.
Fuses:
LP, XT, HS, EC, NOWDT, WDT, NOPUT, PUT, PROTECT, PROTECT_50\%
PROTECT_75\%, NOPROTECT, NOBROWNOUT, BROWNOUT, MCLR, NOMCLR,
LVP, NOLVP, ER_IO, INTRC_IO, ER, INTRC, CPD, NOCPD
Look in the 16F628 data sheet, in section 14.1 "Configuration
bits", for an explanation of these settings.
Look in the CCS manual for an explanation of the #fuses
statement.
(CCS calls the configuration bits "fuses").
Original Post ID: 144516367
