Thank you
pr83
Thank you
PostPosted: Thu Jul 20, 2006 9:41 pm     Reply with quote
Thank You
epideath
PostPosted: Thu Jul 20, 2006 10:36 pm     Reply with quote
Is it possible that the code is set to this:
#device adc=8
If so try changing it to
#device adc=10
Hope this helps
PostPosted: Fri Jul 21, 2006 3:28 am     Reply with quote
I had trouble with the ADC not too long ago. Try setting the ADC_Clock to DIV 2 to 32, see if that effects anything.
Another thing that (oddly) seemed to stablize my reading was
adc_set_channel(0);
read_adc(adc_start_only);
delay_us(10);
adcval = read_adc(adc_start_and_read);
...I have NO IDEA why this helped me, but I know I was getting really strange results between three separate channels, did this and it has been rock solid since. I have to keep it on DIV_BY_2 but thats fine for me.
Neutone
PostPosted: Fri Jul 21, 2006 7:00 am     Reply with quote
adc_set_channel(0);
delay_us(10);
That code will effectivly read the input twice. It is important to pause after changing channels before reading the ADC.
pr83
PostPosted: Fri Jul 21, 2006 7:30 am     Reply with quote
Thanks for the reply.
I did try your suggestions, but it didnt change the output.
I have posted one more message. But this time it has my code in it.
iso9001
PostPosted: Fri Jul 21, 2006 3:12 pm     Reply with quote
pr83: If you are going back and editting your post because you think your code is valuable to other people you can stop. Cause with questions like the ones you asked, its not worth the time of changing the posts.
By the way, if you just edit the body and not the subject I think it won't go back to top.
