Problems with constants
Richi
PostPosted: Thu Jul 20, 2006 3:14 pm     Reply with quote
Iīm using a PIC16F877, so I have to split the Functions. But now I canīt put my Constants and the programm in one function. I tried this code, but it doesnīt work:
Main.c file:
Hauptmenu_A();
Hauptmenu_A.c file:
int Konstanten_Hauptmenu (int x)
BYTE CONST Konstanten_Hauptmenu_A [64] = {
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x10,0x20,0x60,0xC0,0xC0,0x80,0x80,
0x00,0x00,0x30,0x30,0x30,0x30,0x30,0x30,
0x30,0xF0,0xE0,0x00,0xF0,0xF0,0x00,0x00,
0x00,0x00,0x00,0xF0,0xF0,0x00,0xE0,0xF0};
return(Konstanten_Hauptmenu_A[x]);
void Hauptmenu_A (void)
for (x = 0; x < 63; ++x)
Write_Display_Data (Konstanten_Hauptmenu_A[x]);
m = Konstanten_Hauptmenu_A[x];
.... m is always a random number... any Ideas?
rwyoung
PostPosted: Thu Jul 20, 2006 3:38 pm     Reply with quote
Consider two arrays of 32 each.
const int8 A[] = { /*put first 32 values here*/};
const int8 B[] = { /*put second 32 values here*/};
int Konstanten_Hauptmenu(int x)
   if (x>31)
      return(B[x]);
      return(A[x]);
Maybe not the prettiest but might work.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
PostPosted: Thu Jul 20, 2006 3:43 pm     Reply with quote
I made the test program, shown below. It works.
It displays the following:
0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 20 60 C0 C0 80 80 00 00 00 etc.
I tested this with PCM vs. 3.249.
#include <16F877.h>
int8 x;
int8 m;
for(x = 0; x < 63; ++x)
    //Write_Display_Data (Konstanten_Hauptmenu_A[x]);
    m = Konstanten_Hauptmenu(x);
    printf("%X ", m);
main()
Hauptmenu_A();
Richi
PostPosted: Thu Jul 20, 2006 11:32 pm     Reply with quote
Thanks a lot PCM, found the error this morning: I declared the constants not global but in a subroutine local....
