Changing lcd.c driver for 16f88
oyhan
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Sun Jul 16, 2006 5:25 am     Reply with quote
Hi
I want to use 2X16 lcd with 16f88pic.
I need that,
lcd 4 port data port B4,B5,B6,B7
rs pin port B3
E pin port B2
how can I do that please help me for driver....
Thanks....
oyhan
PostPosted: Sun Jul 16, 2006 2:24 pm     Reply with quote
How can I do that..?
PostPosted: Sun Jul 16, 2006 2:32 pm     Reply with quote
Use the LCD driver in this post, instead of the CCS driver.
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
Edit the #define statements at the start of the driver, so the
pin numbers are the same as the pins shown in your post. Example:
#define LCD_DB4   PIN_B4
#define LCD_DB5   PIN_B5
#define LCD_DB6   PIN_B6
#define LCD_DB7   PIN_B7
#define LCD_E     PIN_B2
#define LCD_RS    PIN_B3
// #define LCD_RW    PIN_A2
Also in your post, you don't use the RW pin. So in the driver,
just comment out the line for USE_RW_PIN. Example:
// #define USE_LCD_RW   1
If you don't use the RW pin, then you must connect it to ground
on the LCD.
Also, make sure that your #fuses statement has NOLVP in it.
Make sure that you call the lcd_init() function at the start of your program.
oyhan
PostPosted: Sun Jul 16, 2006 2:42 pm     Reply with quote
Thanks for your answer.
Would you give me short example please...?
like that "Hello world"
I want to learn this subjects..
Best Regards...
PostPosted: Sun Jul 16, 2006 2:56 pm     Reply with quote
#include <16F877.h>
#include "flex_lcd.c"
lcd_init();
lcd_putc("\fHello World");
oyhan
PostPosted: Sun Jul 16, 2006 3:28 pm     Reply with quote
Thank you very much
Dear PCM programmer. It is ok.
I wrote that:
#include <16F88>
#fuses INTRC_IO, MCLR, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock=8000000)
   setup_adc(ADC_OFF);
   setup_adc(NO_ANALOGS);
   SETUP_CCP1(CCP_OFF);
   setup_spi(FALSE);
   setup_counters(RTCC_INTERNAL,WDT_18MS);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
lcd_init();
   output_high(PIN_A2);
   output_low(PIN_A2);
   lcd_putc("hello world");
   lcd_putc("\n PIC 16f88");
oyhan
PostPosted: Tue Jul 25, 2006 5:26 pm     Reply with quote
Hi Dear Friends
I want to do blinking lcd's karakter or may I see lcd's cursor. I use "flex_lcd.c" lcd driver. I want to increment variable like examp=xxxx I have 2 button up and down for increment and decrement. I want to see for this increment and decrement event on lcd but how? Give me an example for that please...
Best Regards...
PostPosted: Wed Jul 26, 2006 10:40 am     Reply with quote
This thread has a list of settings to show or blink the LCD cursor:
http://www.ccsinfo.com/forum/viewtopic.php?t=20237
