set_timer1() Question
Mill
PostPosted: Sun Jul 16, 2006 10:35 am     Reply with quote
According to the following code, I think PIN A1 should be HIGH for 262msecs and LOW for 102msecs. This is not what is happening. I tried changing the SET_TIMER1(X) number but it doesn't seem to change anything.
What is it that I am doing wrong?
int16 delay = 0x4E20;
SET_TIMER1(delay);
SETUP_TIMER_1(T1_INTERNAL|T1_DIV_BY_8);
if(GET_TIMER1() <32768)
OUTPUT_LOW(PIN_A1);
if(GET_TIMER1()>32768)
OUTPUT_HIGH(PIN_A1);
//For some reason the code changed. So I fixed it again.
Crying or Very sad
PostPosted: Sun Jul 16, 2006 12:09 pm     Reply with quote
Re-post your code, but this time, select the box in the posting window
to disable HTML. Example:
x  Disable HTML in this post
Also, post the PIC that you're using.
