How to split a int16 in separate "hundred"
Wolfi
PostPosted: Fri Jul 14, 2006 7:39 am     Reply with quote
Hi all,
I have a long integer number for example 1015 from the adc.
Now I want to get:
thousand: 1
hundred: 0
ten: 1
one: 5
int or char - but how?
sjbaxter
PostPosted: Fri Jul 14, 2006 7:51 am     Reply with quote
You could try something like:
int16 adcvalue;
int8 thous,huns,tens,units;
adcvalue = 1015;
units = (int8)(adcvalue % 10);
tens = (int8)((adcvalue / 10) % 10);
huns = (int8)((adcvalue / 100) % 10);
thous = (int8)((adcvalue / 1000) % 10);
(have read about the MODULUS operator !!)
or if you are going to output the value as ascii text, have a read about the use of printf.
Regards,
Simon.
Wolfi
PostPosted: Fri Jul 14, 2006 10:43 am     Reply with quote
Hi sjbaxter,
o.k. this will work, but much time to calculate... what about printf, can I simple use the int 16 into a char? And do you have a instruction in mind?
rwyoung
PostPosted: Fri Jul 14, 2006 12:30 pm     Reply with quote
With printf (or sprintf) you could use a format specifier string (consult your manual). Then your digits will always fall into the same index of the array or the same location on the screen.
%04d for example.
But depending on how things work out, this might actually take more instruction cycles than using integer division and the modulus operator. The example given above could probably be optimized for higher execution speed.
Rob Young
Wolfi
PostPosted: Fri Jul 14, 2006 12:49 pm     Reply with quote
I dontīt understand the: %10 ... what does it?
Also 1015/100 = 10 - the huns are 0...?
Wolfi
PostPosted: Fri Jul 14, 2006 1:00 pm     Reply with quote
O.k. I found out what %10 means, but this does not help for my problem. I donīt need 10 as result for hundred, I need a 0, when I take my example 1015
rwyoung
PostPosted: Fri Jul 14, 2006 1:06 pm     Reply with quote
int adcvalue = 1015;
int thou, huns, tens, ones;
char temp[8];
// untested and unoptomized, use at your own peril
thou = adcvalue / 1000;
adcvalue %= 1000;
huns = adcvalue / 100;
adcvalue %= 100;
tens = adcvalue / 10;
adcvalue %= 10;
ones = adcvalue;
// and
sprintf(temp,"%04d", adcvalue);
putch(temp[0]);
putch(temp[1]);
putch(temp[2]);
putch(temp[3]);
Rob Young
sjbaxter
PostPosted: Fri Jul 14, 2006 1:07 pm     Reply with quote
This must be a bug in the CCS modulus operator, or you haven't actually divided by 100, as the code I provided works in a few of my applications both on the PIC and in windows c/c#/c++ code !
Regards,
Simon.
PostPosted: Fri Jul 14, 2006 5:12 pm     Reply with quote
And because there is always another way to do it...
The optimised version below is more source code but actually compiles about 130 bytes shorter and is much faster to execute.
void GetDigits(int16 Val, int8 &thous, int8 &huns, int8 &tens, int8 &units)
  tens = 0;
  huns = 0;
  thous = 0;
  while (Val >= 1000)
    Val -= 1000;
    thous++;
  while (Val >= 100)
    Val -= 100;
    huns++;
  while (Val >= 10)
    Val -= 10;
    tens++;
  units = Val;
void main ()
  int16 adcvalue;
  adcvalue = 1015;
  GetDigits(adcValue, thous, huns, tens, units);
  while (1);
Edit: Fixed a bug in the end condition of the while loops. Thanks JohnP.
Wolfi
PostPosted: Sat Jul 15, 2006 3:19 am     Reply with quote
Perfect... thats what Iīm looking for. I had now something like this, but not in this short form!
Thanks!
John P
PostPosted: Sat Jul 15, 2006 7:38 pm     Reply with quote
Uh, not so fast with the thanks there. Shouldn't all those
while (Val > 1000)
etc lines there be
while (Val >= 1000) ?
If you use the code as listed and the incoming value were (let's say) exactly 1000, the first test would never indicate any thousands, but would go on to the next stage with val still equal to 1000. Then it would count down 9 hundreds and go on to the final stage with 100 left, then count 9 tens and finally there'd be 10 units. Not good.
PostPosted: Sun Jul 16, 2006 7:07 am     Reply with quote
while (Val > 1000)
etc lines there be
Oops... Embarassed
Thanks for pointing out the error, I've edited the sample program to fix this.
