PCF8583 Clock ic
The Puma
PCF8583 Clock ic
PostPosted: Fri Jul 14, 2006 8:19 am     Reply with quote
Can someone help me with a code to display hours, minutes,seconds
and on the second line day, month, year
I tried several think but i have only mintes and seconds on the lcd
epideath
PostPosted: Fri Jul 14, 2006 8:57 am     Reply with quote
please post some of your code.
The Puma
PostPosted: Fri Jul 14, 2006 9:02 am     Reply with quote
Here is the code
#include <18F4620>
#fuses HS,NOWDT,NOBROWNOUT,NOPUT,NOLVP,DEBUG,NOSTVREN,NOPROTECT
#include <flex_lcd420>
#include <pcf8583>
void main() {
   while (TRUE) {
      Gettime();
      lcd_gotoxy(1,1);
      printf(lcd_putc,"Seconds: %01u%01u:%01u%01u",time[2],time[3],time[0],time[1]);
      delay_ms(50);
#ifndef PCF8583_SDA
#define PCF8583_SDA PIN_C4
#define PCF8583_SCL PIN_C3
#endif
#use i2c(master,sda=PCF8583_SDA,scl=PCF8583_SCL,FORCE_HW,RESTART_WDT)
// Defines address for Read and Write ON I2C BUS
#define PCF8583_ADDR_WRITE      0xA0
#define PCF8583_ADDR_READ       0xA1
// Defines internal registers
#define CONTROL_STATUS_REG      0x00
#define HUNDREDTH_OF_SEC_REG    0x01
#define SECONDS_REG             0x02
#define MINUTES_REG             0x03
#define HOURS_REG               0x04
#define YEAR_DATE_REG           0x05
#define WEEKDAYS_MONTHS_REG     0x06
#define TIMER_REG               0x07
#define ALARM_CONTROL_REG       0x08
#define ALARM_HUNDREDTH_OF_SEC  0x09
#define ALARM_SECONDS           0x0A
#define ALARM_MINUTES           0x0B
#define ALARM_HOURS             0x0C
#define ALARM_DATE              0x0D
#define ALARM_MONTH             0x0E
#define ALARM_TIMER             0x0F
#define FREE_RAM_START          0x10
#define FREE_RAM_END            0xFF
// Defines seconds register (RESET STATE: ???? ????)
struct {
    byte UNITS_BCD      :4;     // Unit seconds BCD format
    byte TENS           :3;     // Ten seconds, 0 to 5 binary
    byte NOT_UNUSED     :1;     // NOT USED
} SECONDSREG;
// Defines minutes register (RESET STATE: ???? ????)
struct {
    byte UNITS_BCD      :4;     // Unit minutes BCD format
    byte TENS           :3;     // Ten minutes, 0 to 5 binary
} MINUTESREG;
// Defines hours register (RESET STATE: 0000 0000)
typedef struct {
    byte UNITS_BCD      :4;     // Unit hours BCD format
    byte TENS           :2;     // Ten hours, 0 to 2 binary
    byte AM_PM_FLAG     :1;     // 0 -> AM, 1 -> PM
    byte FORMAT         :1;     // 0 -> 24h format, 1 -> 12h format
} HOURSREG;
// Defines yeardate register (RESET STATE: 0000 0001)
typedef struct {
    byte UNIT_DAYS_BCD  :4;     // Unit days BCD format
    byte TEN_DAYS       :2;     // Ten days, 0 to 3 binary
    byte YEAR           :2;     // 0 to 3 binary, reads as 0 if the mask flag is set
} YEARDATEREG;
byte time[4];
byte decD2hexD(byte value) {
   return(value%10+16*(value/10));
byte hexD2decD(byte value) {
   return(value%16+10*(value/16));
byte pcf8583_read(byte address) {
   byte data;
   i2c_start();
   i2c_write(PCF8583_ADDR_WRITE);
   i2c_write(address);
   i2c_start();
   i2c_write(PCF8583_ADDR_READ);
   data=i2c_read(0);
   i2c_stop();
   return(data);
void Gettime() {
   SECONDSREG=pcf8583_read(SECONDS_REG);
   MINUTESREG=pcf8583_read(MINUTES_REG);
   time[0]=hexd2decD(SECONDSREG.TENS);
   time[1]=hexd2decD(SECONDSREG.UNITS_BCD);
   time[2]=hexd2decD(MINUTESREG.TENS);
   time[3]=hexd2decD(MINUTESREG.UNITS_BCD);
treitmey
PostPosted: Fri Jul 14, 2006 12:10 pm     Reply with quote
Take a look at M41T80
http://www.ccsinfo.com/forum/viewtopic.php?t=24125
It is also I2C and using BCD. This may just require a remaping of the register locations. See how I printed them.
PostPosted: Tue Jul 18, 2006 9:55 am     Reply with quote
Nobydy can help me with the code how to display the year field?
Please give me some support
