Richi Guest
MCP23016 |
Posted: Thu Jul 13, 2006 10:33 am |
Hi Friends,
want to use a MCP23016. Now I think my code is o.k... I measured with a oszilloskop and canīt find an error, The initial sequenz (I/O direction) is sended but if I read from any registerpair I always get 0xFF in the WATCH window- as I also can se on the oszilloskop. So the adress and everything is o.k. I also get an acknolage.
Second: the INT Pin is always low- but maybe it is because the part is not initialized?
(Is it really necessary to give a 20ĩs delay between every Write/read? What about using the Fast-mode?)
The Code:
void Write_I2C_MCP ( int MCP_Commando, long MCP_Data )
MCP_Data_L = make8(MCP_Data,0);
MCP_Data_H = make8(MCP_Data,1);
I2C_start();
delay_us(20);
I2C_write( 0x40 ); // Adresse
delay_us(20);
I2C_write( MCP_Commando );
delay_us(20);
I2C_write( MCP_Data_H );
delay_us(20);
I2C_write( MCP_Data_L );
delay_us(20);
I2C_stop();
delay_us(20);
int Read_I2C_MCP ( int MCP_Commando )
I2C_start();
delay_us(20);
delay_us(20);
delay_us(20);
I2C_write( 0x41 ); // Adresse
delay_us(20);
MCP_Data_lesen_H = I2C_read();
delay_us(20);
MCP_Data_lesen_L = I2C_read();
delay_us(20);
I2C_stop();
delay_us(20);
return(MCP_Data_lesen_L, MCP_Data_lesen_H);
#INT_EXT
void isr_ext()
NOP;
void main (void)
enable_interrupts(INT_EXT);
EXT_INT_EDGE(H_TO_L);
Write_I2C_MCP ( 0x04, 0x0000 );
Write_I2C_MCP ( 0x0A, 0x0101 );
Write_I2C_MCP ( 0x06, 0xC700 );
delay_ms(1);
Write_I2C_MCP ( 0x02, 0x0000 );
for (;;)
Read_I2C_MCP ( 0x06 );
Read_I2C_MCP ( 0x08 );
Write_I2C_MCP ( 0x00, 0xFF00 );
Posted: Thu Jul 13, 2006 11:34 am |
There's a driver for the MCP23016 in the code forum:
http://www.ccsinfo.com/forum/viewtopic.php?t=21797
Also, if you had logged in, then you could delete the double post
that you made. Guests can't delete their extra posts. |
Richi Guest
Posted: Fri Jul 14, 2006 7:21 am |
Hi PCM,
I already had seen this sample C-File. And I found out that my programm is nearly the same. But it didnīt work! WHY? After a third and fourt compare I found out that i forgot to send a new start condition when reading...
Thanks |
