Need help with interrupts!!
ajshah23
PostPosted: Thu Jul 13, 2006 7:41 pm     Reply with quote
These interrupts are becoming very frustrating! Can someone PLEASE help??
The function of the circuit is to display characters on an LCD when a pushbutton is pressed and held down, and to turn on an RFID reader antenna when the button is released. The reader and LCD work fine separately. Here is what I have so far, but only the display works :(
#include <16F877>
#fuses HS,NOWDT,NOPROTECT,NOLVP, NOBROWNOUT
#USE RS232(BAUD=9600, XMIT=PIN_C6,RCV=PIN_C7, bits=8, PARITY=N)
#include <lcd>
#include <input>
#rom 0x2100={1,2,3,4}
#use fast_io(B)
#define IRX_B_TRIS 0b10000010
#define DOOR_BUTTON PIN_B0
//#byte PORTD = 8
//#define ALL_OUT 0
// global flag to send processor into sleep mode
short sleep_mode;
// external interrupt when button pushed and released
#INT_EXT
void ext_isr() {
static short button_pressed=FALSE;
   if(!button_pressed)        // if button action and was not pressed
      button_pressed=TRUE;    // the button is now down
      sleep_mode=TRUE;        // activate sleep
      //printf("The processor is now sleeping.\r\n");
      ext_int_edge(L_TO_H);   // change so interrupts on release
   else                       // if button action and was pressed
      button_pressed=FALSE;   // the button is now up
      sleep_mode=FALSE;       // reset sleep flag
     ext_int_edge(H_TO_L);   // change so interrupts on press
   if(!input(PIN_B0))         // keep button action sychronized wth button flag
      delay_ms(100);             // debounce button
int checkid();
do{
int m;
int lcd_on;
int lcd_off;
int startaddr;
int milkaddr = 0001;
int breadaddr = 0002;
int juiceaddr = 0003;
int endaddr = 0003;
int freq = 0001;
//sleep_mode=TRUE;
ext_int_edge(H_TO_L);      // init interrupt triggering for button press
enable_interrupts(INT_EXT);// turn on interrupts
set_tris_b(IRX_B_TRIS);
if(sleep_mode==FALSE){
   while(sleep_mode==FALSE){
   do{
      m = checkid();//this will return an integer m
   }while(m==0);
   //LCD should be initialzed here to indicate that something was removed/replaced
      if(m==1)
            if(read_eeprom(milkaddr)==0001)
               write_eeprom(milkaddr, 0000);
               write_eeprom(milkaddr, freq);
      else if(m==2)
            if(read_eeprom(breadaddr)==0001)
               write_eeprom(breadaddr, 0000);
               write_eeprom(breadaddr, freq);
         delay_ms(300);
         lcd_putc(" Bread ");
         lcd_putc('\f');
      else if(m==3)
            if(read_eeprom(juiceaddr)==0001)
               write_eeprom(juiceaddr, 0000);
               write_eeprom(juiceaddr, freq);
else if(sleep_mode==TRUE){
lcd_init();
while(sleep_mode==TRUE){
                     //CODE
}while(TRUE);//end of huge do while loop right after main begins
The check id funciton works fine, it is just the interrupts.
Can someone please look into this???
Mark
PostPosted: Thu Jul 13, 2006 8:35 pm     Reply with quote
You shouldn't have this code in the do loop
int m;
int lcd_on;
int lcd_off;
int startaddr;
int endaddr = 0003;
int freq = 0001;
//sleep_mode=TRUE;
You should initialize this variable
short sleep_mode;
ajshah23
Tried it
PostPosted: Fri Jul 14, 2006 11:05 am     Reply with quote
Thank you Mark.
I tried what you said, but there was no change. The interrupt is not being called properly. Would it be a problem with disabling the interrupts???
rwyoung
PostPosted: Fri Jul 14, 2006 12:28 pm     Reply with quote
Probably not stopping your code from running but certainly not good in an interrupt. Don't call delay_ms() in your ISR. Ties up the entire processor doing nothing, including servicing future interrupt events.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
