Out of memory - Using 12-Bit part (16C57)
edbfmi
PostPosted: Thu Jul 13, 2006 2:53 pm     Reply with quote
I see where this question has been answered a 1000 times for 14 bit parts using the #device *=16 command. My problem is I am using a PIC16C57 and it is a 12bit part. What can I do to let the compiler use the extra three pages of memory?
PostPosted: Thu Jul 13, 2006 3:05 pm     Reply with quote
That device statement affects RAM usage. Your question is about ROM.
Page sizes on the 16C57 are relatively small -- they're only 512 bytes.
Compare this to 2KB pages on the 16F877. In CCS, a function must
fit within a ROM page. It can't span 2 or more pages. So one possible
reason for "out of ROM" is that a function is too large. You need to
reduce the size. Split it up into two or more functions. Also, avoid
using floating point with such a small PIC.
PostPosted: Thu Jul 13, 2006 3:20 pm     Reply with quote
#device *=8
Your chip, only supports 72 bytes of RAM, so only needs a 8 bit address, .
So:
#include <16C57>
#device *=8
void main() {
   int array[16];
   int array2[16];
   int array3[16];
   int test,test1,test2;
   //Rest of code here
Will fit array2, and array3, into the higher banks.
Rmember that you will be 'stuck' with the largest possible element in the higher banks, being 16 bytes.
PostPosted: Thu Jul 13, 2006 4:12 pm     Reply with quote
Sorry. As soon as I saw the "three pages", I immediately jumped on
it as a ROM issue.
PostPosted: Fri Jul 14, 2006 3:56 am     Reply with quote
Like me, - only 'human' (or near at least...)... Smile
It is an oddity really, that the 12 parts default to using a 5bit RAM address, while the 16 parts default to a 8bit address. Relatively poorly documented.
