input_?()
input_?()
PostPosted: Wed Jul 12, 2006 7:08 pm     Reply with quote
Is posible to read 8 pins of different ports simultaneously?
for example, I know that using input_b() I can read 8 bits of portb, but is it posible pre-configure any of them ? may be using any #USE_?? or something in order to make a "virtual port" using pins from diferent ports ?.
Thank you.
asmallri
PostPosted: Wed Jul 12, 2006 7:58 pm     Reply with quote
If you mean simultaneously as in one instruction. No. The underlying PIC does not support virtualization so there is no way the compiler can do it.
Regards, Andrew
PostPosted: Wed Jul 12, 2006 8:30 pm     Reply with quote
Something like this would be about the best you can do.
#include <16F877.H>
// Port addresses for 16F877.
#byte PortA = 5
#byte PortB = 6
#byte PortC = 7
#byte PortD = 8
#byte PortE = 9
// Read various pins on different ports,
// pack them into a byte, and return it.
int8 read_pins(void)
int8 retval;
#bit b0 = retval.0
#bit b1 = retval.1
#bit b2 = retval.2
#bit b3 = retval.3
#bit b4 = retval.4
#bit b5 = retval.5
#bit b6 = retval.6
#bit b7 = retval.7
b0 = bit_test(PortA, 0);
b1 = bit_test(PortA, 2);
b2 = bit_test(PortB, 1);
b3 = bit_test(PortB, 4);
b4 = bit_test(PortB, 5);
b5 = bit_test(PortC, 0);
b6 = bit_test(PortC, 1);
b7 = bit_test(PortC, 2);
return(retval);
int8 value;
value = read_pins();
PostPosted: Fri Jul 14, 2006 11:42 am     Reply with quote
Ok, thank you. I'll try with that.
