Configuration Bit Option Problem
Jerry I
PostPosted: Thu Jul 24, 2003 10:54 am     Reply with quote
Thanks in advance for any help.
I am using for the first time the PIC18F2320
My problem is I cannot get the crystal to Oscillate with MCLR is high.
I know this chip has many fuses for internal & external oscillator, power modes, oscillator switch modes.
What I am seeing on scope if MCLR is LOW the Oscillator is running. If MCLR is HI (for normal operation) the oscillator starts then stops after approx 1/2 sec. There must me some power mode or oscillator switch mode that disables the oscillator.
WHAT FUSES DO I USE TO DISABLE THIS. I have used the 18F252 with no problems.
MY current Fuses are
#FUSE HS, NOWDT, NOPROTECT, NOLVP, PUT
I know there are other fuses for power modes, oscillator switch modes like IESO, NOIESO, MCLR, NOMCLR, FCMEN, NOFCMEN
Thanks again for any help.
___________________________
Original Post ID: 144516315
Re: Configuration Bit Option Problem
PostPosted: Thu Jul 24, 2003 3:50 pm     Reply with quote
:=What I am seeing on scope if MCLR is LOW the Oscillator is running. If MCLR is HI (for normal operation) the oscillator starts then stops after approx 1/2 sec. There must me some power mode or oscillator switch mode that disables the oscillator.
This problem could be caused by letting your program
fall through the end of main(). CCS puts a SLEEP instruction
there, and this would cause the oscillator to stop.
Example:
main()
printf("Hello World\n\r");
The program above will execute and then the oscillator will
stop. That's because it hits the hidden SLEEP instruction
at the end of main(). To prevent this problem, put a "forever"
loop at the end of main(). Example:
main()
Original Post ID: 144516330
Jerry.I
PostPosted: Thu Jul 24, 2003 4:26 pm     Reply with quote
This is not an issue of the Pic going to sleep. I have compiled the same program using the device 18F252 and all runs fine.
I still think it can be a problem with the configuration bits.
Thanks.
:=:=What I am seeing on scope if MCLR is LOW the Oscillator is running. If MCLR is HI (for normal operation) the oscillator starts then stops after approx 1/2 sec. There must me some power mode or oscillator switch mode that disables the oscillator.
:=This problem could be caused by letting your program
:=fall through the end of main(). CCS puts a SLEEP instruction
:=there, and this would cause the oscillator to stop.
:=Example:
:=main()
:=printf("Hello World\n\r");
:=The program above will execute and then the oscillator will
:=stop. That's because it hits the hidden SLEEP instruction
:=at the end of main(). To prevent this problem, put a "forever"
:=loop at the end of main(). Example:
:=main()
:=while(1);
Original Post ID: 144516331
