Run PCM Compiler in PCWH IDE
tcwong3
PostPosted: Sat Jul 08, 2006 11:58 am     Reply with quote
I have both PCM and PCWH.
I was running PCM in MPLAP with plug-in.
My question is I still need to use MPLAP when developing 16F series program? Or I can run PCM in the my newly purchased PCWH IDE?
PostPosted: Sun Jul 09, 2006 1:43 am     Reply with quote
PCWH includes the PCM compiler. Notice in this screenshot of PCWH
that it's being used to create a program for the 16F877:
http://www.ccsinfo.com/images/content/C_aware_editor.gif
So the answer is: No, you don't need MPLAB if you have PCWH.
If you use PCWH as your IDE, you must use (typically) the ICD-U40
as your debugger. You can't use the Microchip ICD2 with PCWH.
tcwong3
PostPosted: Sun Jul 16, 2006 6:14 am     Reply with quote
Thks for your reply.
I tested it with the following steps:
(1) typed a file "test.c" as per sample in your graphic file
(2) manually craeted project and selected test.c as main file
(3) select 16f877 as device
(4) compiled it
I got the following prompt for the IDE:
Unable to write to C:\Program\PCWH\PICC\Quick Start\Test.pjt.
Could you pls help me to fix this problem?
Thks
p/s Yes. I purchased ICD-U40 from CCS as well, do you have any quick start guide?
