SET BIT IN PIC REGISTER
JaSoN
PostPosted: Fri Jul 07, 2006 8:53 am     Reply with quote
HI, how can I set bit0 'ON' in PIC register PIE1?
epideath
PostPosted: Fri Jul 07, 2006 9:07 am     Reply with quote
bit_set(PIE1,0);
where PIE1 is the register where PIE1 is located on your PIC.
PostPosted: Fri Jul 07, 2006 9:19 am     Reply with quote
Further answers:
#byte PIE1=(put address here to suit the chip concerned)
#bit PIE1BIT0=PIE1.0
Then PIE1BIT0=1 will set it, and PIE1BIT0=0 will clear it.
Or, since PIE1.0, is normally the 'timer1 interrupt enable' bit, use the inbuilt instruction:
The latter has the advantage of remaining portable, if you change to another chip (16 to 18 for example). In general, I'd recommend this.
JaSoN
PostPosted: Fri Jul 07, 2006 9:45 am     Reply with quote
THANKS VERY MUCH!!
Gabor
PostPosted: Tue Jun 19, 2012 6:42 am     Reply with quote
Ttelmah wrote:
Further answers:
Hi I tried this:
#BYTE RCSTA=0x18;
#BIT RCSTABIT7=RCSTA.7;
But I am given an "Expecting a declaration" error message.
What is my mistake?
jeremiah
PostPosted: Tue Jun 19, 2012 7:47 am     Reply with quote
Try taking out the semicolons
Gabor
PostPosted: Tue Jun 19, 2012 10:31 am     Reply with quote
Thank you it's work!!!
