Serial Comm
Serial Comm
PostPosted: Thu Jul 06, 2006 3:05 pm     Reply with quote
I need help:
I will appreciate anybody who can help me
I write a VB GUI to test the port of a PIC microcontroller
The GUI will send data from serial port to turn on or turn off a pin of the microcontroller (let say use portb of PIC)
Here is my PIC code:
#include <18F452>
#fuses XT,NOWDT,NOPROTECT,NOLVP
char PinNumber,PinState;
         PinNumber = getc();
      PinState = getc();
      output_b(PinNumber);
      output_b(PinState);
and here is my VB6 code
Private Sub Command1_Click()
Dim PinNumber As Long
Dim PinState As Long
'  Get Pin Number
PinNumber = cboPinNumber.ListIndex
'  Get Pin State
If OptState(0).Value = True Then
    PinState = 0
Else
    PinState = 1
End If
' Send Out Data
MSComm1.Output = Chr$(255) & Chr$(PinNumber) & Chr$(PinState)
End Sub
Private Sub Form_Load()
    Dim Pins As Long
'  Add the pin numbers 0 to 7 to cboPinNumber
'  PortD RD0 - RD7
    For Pins = 0 To 7
    cboPinNumber.AddItem CStr(Pins)
    Next Pins
    ' Default to Pin 0 being selected
    cboPinNumber.ListIndex = 0
    ' Default to optState(0) being selected
    '  Use COM1
    MSComm1.CommPort = 1
    ' 2400 baud, no parity, 8 data bits, 1 stop bit
    MSComm1.Settings = "9600,N,8,1"
    ' Disable DTR
    MSComm1.DTREnable = False
    ' Open the port
    MSComm1.PortOpen = True
End Sub
Private Sub Form_Unload(Cancel As Integer)
MSComm1.PortOpen = False
End Sub
PostPosted: Fri Jul 07, 2006 4:25 am     Reply with quote
'Output_b', puts the _byte_ out on the whole port. As written, your VB program will send three bytes '255', then the Pin number, then the Pin state. Your receive code, will only look for two bytes (so will take '255', as the first value, then the pin number as the second), and will output first one, then the other byte to the port. You will never see the first, since it will only be present for one-millionth of a second, and the port will then end with the second byte (the pin number), present as a bit pattern on the output pins. The code will then loop back, and retrieve the 'value', but will then sit waiting, because nothing else arrives (until the next button event in the VB code).
You need something to turn the numbers into the required bit patterns.
#include <18F452>
void main() {
    int8 bit_pattern=0;
    int8 mask;
    while(1) {
        //Wait for the '255' header character
        while (getc()!=255) ;
        //Now retrieve the pin number and 'state'
        PinNumber = getc();
        PinState = getc();
        mask=1<<PinNumber;
        //Now you have a 'mask', with a '1' in the bit corresponding
        //to the required pin number.
        if (PinState=1) bit_pattern |= mask;
        //Set the required bit if the 'state' is 1
        else bit_pattern &= ~(mask);
        //otherwise turn off the specified bit.
        output_b(bit_pattern);
PostPosted: Wed Jul 26, 2006 2:09 pm     Reply with quote
Can you explain how is this statement work?
I am really new into this
mask=1<<PinNumber;
newguy
PostPosted: Wed Jul 26, 2006 3:56 pm     Reply with quote
mask=1<<PinNumber;
Let's say PinNumber = 3.
mask = 1 << 3 means shift 0x01 left 3 times (in other words, multiply 1 by 2 three times), then assign this value to "mask". After all this is done, mask will be 0x08. Same thing as saying 1 * (2^3) = 8.
