Bertrand Guest
Pointer problem |
Posted: Thu Jul 06, 2006 2:03 am |
I've been trying to use pointers with a small buffer but it doesn't work. I've been searching for my error for some hours and I did not find it. May someone have a look at it please ?
I declare a small table this way:
byte pagebuffer[128];
I then pass a pointer to this buffer to a function:
READ_EXT_EEPROM_PAGE(address,&pagebuffer[0]);
Here is the prototype of this function:
void read_ext_eeprom_page(EEPROM_ADDRESS address, BYTE *dataptr)
In the function, I do this (data is a byte, i is from 0 to 127):
dataptr[i] = data;
If, immediatly below that, I do
printf("%X=%X ",data,dataptr[i]);
...I see that the values are equal. Good.
But, when the READ_EXT_EEPROM_PAGE function returns, the content if pagebuffer is not changed.
Does someone has any idea ? I don't have much hair left to pull out...
Bertrand |
Posted: Thu Jul 06, 2006 7:04 am |
What you have posted, should work. You need to look for other possibilities. For instance is 'i' actually changing as you expect (you don't test this)?. if not, then the same byte could be being changed on every loop. Alternatively, something else below pagebuffer, overwriting the values.
Neutone
Re: Pointer problem |
Posted: Thu Jul 06, 2006 9:00 am |
Bertrand wrote: |
dataptr[i] = data;
Bertrand |
I think this will work.
*(dataptr+i) = data; |
Posted: Thu Jul 06, 2006 9:06 am |
Both should work.
C, makes no real distinction between pointers, and arrays. So if you have an array 'fred', you can access fred[10], and get exactly the same result as *(fred+10).
I must admit I do suspect 'something else'. There is no error checking, so it is perfectly possible that areas outside the required array are being accessed.
Posted: Thu Jul 06, 2006 9:44 pm |
I tried to make a test program based upon your description.
It works OK. It displays the following:
Quote: | 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 14 15 etc.
I tested this with PCH vs. 3.249. If this program doesn't work,
then post your compiler version.
Code: | #include <18F452>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
void READ_EXT_EEPROM_PAGE(int16 address, int8 *dataptr)
int8 data;
int8 i;
data = (int8)address;
i = (int8)address;
dataptr[i] = data;
int8 i;
int16 address;
int8 pagebuffer[128];
// Zero the buffer.
for(i = 0; i < 128; i++)
pagebuffer[i] = 0;
// Fill buffer with data read from eeprom.
for(address = 0; address < 128; address++)
READ_EXT_EEPROM_PAGE(address, &pagebuffer[0]);
// Display the buffer.
printf("%X ", pagebuffer[i]);
Bertrand Guest
Posted: Fri Jul 07, 2006 6:19 am |
Hi all,
Thanks for your replies. Actually, Ttelmah was right... what a shame of me ! There was a problem with the index, i.
It works well now that I have fixed it...
Sorry and thanks a again !
Bertrand |
Posted: Fri Jul 07, 2006 8:09 am |
Lesson is 'look at everything, even if you think it is right'.
Glad you have found it.
