migrating from 16f877 to 18f4525
cjusto
PostPosted: Thu Jun 29, 2006 3:02 pm     Reply with quote
hi forum!
i was programming a 16f877A. i tried to use a 18f4525 and i am unable do use it.
the equipment is provided by my uni. hardware is MPLAB ICD2 and the demoboard. software i am using is mplab IDE. i upraded to the v7.40. and i use the ccs plugin. it is the version 3.207 .
when i try to compile an error occurs "The extended CPU Mode configuration bit is enabled, but the program that was loaded was not built using CPU instructions."
how can i solve this?
any ideas?
PostPosted: Thu Jun 29, 2006 3:45 pm     Reply with quote
You asked this question back in May. Did you try my answer ?
http://www.ccsinfo.com/forum/viewtopic.php?t=27131
A person in this thread had the same problem and fixed it by
that method.
http://www.ccsinfo.com/forum/viewtopic.php?t=23072&start=6
cjusto
PostPosted: Thu Jun 29, 2006 3:57 pm     Reply with quote
hi PCM programmer.
yeah, i posted that. at that time i tried and i had no success.
now i tried it, and it works.
thanks.
