Serial port and sleep
Eugeneo
PostPosted: Mon Jun 26, 2006 3:19 pm     Reply with quote
How do you turn off the serial usart during sleep. Will this work, the cpu seems to keep resetting.
Sleep code
temp=input(pin_B2);
temp=input(pin_B5);
VCC_OFF;
PORT_B_PULLUPS(0x01);            // one pull up enabled on port B0 ext int for wake
disable_interrupts(INT_TBE);     // keep off all serial ports until wake up
disable_interrupts(INT_RDA);     // keep off all serial ports until wake up
Wake code
output_float(pin_B2);            //release RX pin form low state
output_float(pin_B5);            //release TX pin form low state
enable_interrupts(INT_RDA);     // Turn on serial port
enable_interrupts(INT_TBE);     // Turn on serial port
PostPosted: Mon Jun 26, 2006 3:38 pm     Reply with quote
How do you turn off the serial usart during sleep ?
Do this:
setup_uart(FALSE);
To turn it back on:
setup_uart(TRUE);
This is in the manual.
Note that this only works with the hardware UART.
Eugeneo
PostPosted: Mon Jun 26, 2006 3:39 pm     Reply with quote
Thank-you
