rt_joerg
RC3 always detects HIGH |
Posted: Mon Jun 26, 2006 2:15 am |
at the moment I have a problem with the 16F690 I haven’t found a solution in this board.
The 16F690 is used to detect a pulse to ground at nine inputs (RA0, RA1, RA4, RB4, RC1, RC2, RC3, RC4 and RC6). They are all working well but RC3. It always detects a High-Level, regardless whether it has VCC or GND-Level.
I am not using the ADC but reading the ANSEL-Register (ptr = 0x11E; putc(*ptr);) gives a 0x88;
These are my settings:
#fuses INTRC_IO, NOPROTECT, BROWNOUT, NOMCLR, NOCPD, WDT, PUT, NOIESO, NOFCMEN, BROWNOUT_NOSL
#use rs232(BAUD=9600, XMIT=PIN_B7, RCV=PIN_B5, RESTART_WDT, PARITY=E)//, ERRORS)
Does anyone know about this problem and has a hot tip for me?
Many thanks in advance.
BTW: I tried a different PIC. Hence, I can eliminate defect hardware. |
