Jeremy Duarte Guest
PIC16F628, I/OS do not respond, TX is inverted |
Posted: Tue Jul 22, 2003 1:02 pm |
Hi everyone,
I have a strange problem with a PIC16F628.
I am using pin A0, A1, A2 as I/Os, the comparators are shut down. My program was working well until I decided to connect TTL signals coming from different equipment to pin B4, B5, B6.
B4, B5, B6 are configured as inputs.
The same program behave strangely, A0, A1, A2 do not change any more and the transmit pin of the UART gets inverted. When I send something I get the opposite.
But when I disconnect the data lines from pin B4, B5, B6 everything works again.
I use fixed i/os. Here are the configuration bits I set in MPLAB
with the PICStart Plus : crystal HS (20MHz), Watchdog disabled, power up is on, brown out is on, everything else is disabled.
Even if I try this very simple program the problem occurs:
#include "pic16f628.h"
#use fixed_io(outputs_a=PIN_A0, PIN_A1, PIN_A2)
#use rs232(baud=4800, xmit=PIN_B2, rcv=PIN_B1)
CMCON=0x07; // comparator shut down
output_a(0xFF);
output_low(PIN_A0);
output_high(PIN_A0);
What could be wrong?
Thanks in advance.
___________________________
Original Post ID: 144516250 |
Re: PIC16F628, I/OS do not respond, TX is inverted |
Posted: Tue Jul 22, 2003 1:13 pm |
:=My program was working well until I decided to connect TTL signals coming from different equipment to pin B4, B5, B6.
:=B4, B5, B6 are configured as inputs.
First thought: RB4 is the PGM pin on this PIC.
Do you have NOLVP in the #fuses statement ?
If not, put it in there.
Original Post ID: 144516253 |
