question about compiler files
roby
PostPosted: Thu Jun 22, 2006 3:20 am     Reply with quote
When I compile a file (F9 command) the compiler creates several files, I haven't understood how I can tell the compiler to create only .hex files and not .cof and so on
Thank you
Humberto
PostPosted: Thu Jun 22, 2006 7:27 am     Reply with quote
What compiler do you have ? PCB, PCM, PCH, PCWH.
Reading the CCS Compiler Manual you will find how to setup the compiler options in the chapter: "Invoking the Command Line Compiler"
Humberto
roby
PostPosted: Thu Jun 22, 2006 8:10 am     Reply with quote
How can invoke if I use IDE compiler?
PostPosted: Thu Jun 22, 2006 9:35 am     Reply with quote
In CCS IDE: Options/File Formats
In MPLAB: Project/Build Options.../Project/CCS C Compiler/General
