Program problem
STIX
Program problem
PostPosted: Sat Jun 17, 2006 4:10 pm     Reply with quote
I'm having problem with this simple program below. When I try to compare the value in the array "d" to see if it is negative, the red LED does not come on. However, the green LED does come on for a positive value. So I don't know what's wrong with the code, can anyone help me out? Thanks.
#include <16f877a.h>
#device  *=16
#include <math.h>
#fuses HS,NOWDT,NOPUT,NOPROTECT,NODEBUG,BROWNOUT,NOLVP,NOCPD,NOWRT
#byte PORTB    = 0x06
#byte TRISB    = 0x86
#bit  redLED   = PORTB.4
#bit  greenLED = PORTB.7
#bit  TRISB4   = TRISB.4
#bit  TRISB7   = TRISB.7
float const d[4] = {-1, 1, 1, -1};
void main (void)
   int k;
   TRISB4 = 0;
   TRISB7 = 0;
   for (k = 0; k <= 3; k++) {
      if (d[k] < 0)
         turn on red LED
      if (d[k] > 0)
         turn on green LED
Eugeneo
Re: Program problem
PostPosted: Sat Jun 17, 2006 4:25 pm     Reply with quote
Have you tried using
if ((float)d[k] < 0)
SherpaDoug
PostPosted: Sat Jun 17, 2006 4:53 pm     Reply with quote
The pseudo-code you posted should work. In the real code make sure you never assign d[k] to a simple int as ints default to unsigned so -1 will become 255. Its a mistake we have all made zillions of times.
STIX
PostPosted: Sat Jun 17, 2006 5:18 pm     Reply with quote
I did this:
if ((float)d[k] < 0) and it worked.
However, I don't understand what the problem was before. In my declaration, I made "float const d[4] = {-1, 1, 1, -1}", so why do I have to cast "d" as a float again?
And why did:
if (d[k] > 0) work in the first place then?
epideath
PostPosted: Sat Jun 17, 2006 10:51 pm     Reply with quote
I believe it didn't work becasue you were using a const of 0 as in
d[k] < 0;
so it defaulted to an integer value. As another poster had suggested this would then default to -1 which would be 255. Possibly if you had used
d[k] < 0.0;
so it forces it to use float then it may have worked.
PostPosted: Sat Jun 17, 2006 11:17 pm     Reply with quote
It works with PCM vs. 3.249. I took your program and added some
code to turn into a full test program. It displays the following output:
Red LED On
Green LED On
Green LED On
Red LED On
void main (void)
int k;
for(k = 0; k <= 3; k++)
    if(d[k] < 0)
       printf("Red LED On\n\r");
    if (d[k] > 0)
        printf("Green LED On\n\r");
