content of a specific location in a string
hadeelqasaimeh
PostPosted: Sat Jun 17, 2006 2:29 am     Reply with quote
hi all
i need to know a content of a specific location in some string i have recieved from rs-232 port.
for example i need to know whats in S[10] in location 10,,so how to do?
thanx
PostPosted: Sat Jun 17, 2006 3:09 am     Reply with quote
In C, there is a 'cross correlation', between what are called 'pointers', and 'arrays'. If (for instance), you have:
char str[20];
//and then call:
gets(str);
//which sends the 'pointer' to 'str', to the function, then after the data is retrieved:
str[0] will contain the first character received.
So, 'strings', are just arrays of characters (with a '0' in the last location used), and can be accessed either way at will. Using the 'pointer' notation:
*(str+10)
will be the 'contents' of the _eleventh_ character in the string. Remember that throughout C, things arrays, pointers etc., are 'zero referenced', so a ten element string (str[10]), has elements str[0] to str[9]. Also that for a string, there must be a terminating '0', so only nine useable characters can actually be held in such a ten element array.
Forgetting that you need this 'extra' character, and the use of the zero location, are the two commonest problems with strings in C.
garage
PostPosted: Sat Jun 17, 2006 11:41 pm     Reply with quote
please if you have a simple example code of this!!
thank you
hadeelqasaimeh
PostPosted: Sat Jun 17, 2006 11:42 pm     Reply with quote
thanx
Mark
Re: content of a specific location in a string
PostPosted: Sun Jun 18, 2006 9:00 pm     Reply with quote
hadeelqasaimeh wrote:
hi all
thanx
The 10th character in a string is s[9].
hadeelqasaimeh
so....
PostPosted: Mon Jun 19, 2006 12:08 am     Reply with quote
hi
i understand that
from first reply
now mark said
i think this different!!!!so what to do guyes? Shocked
if there is some example
asmallri
PostPosted: Mon Jun 19, 2006 12:31 am     Reply with quote
assuming the following:
        char Mesg[20];
   sprintf(Mesg, "Hello, world");
the line
      printf("%c", Mesg[5])
will print the , character
the line
       printf("%s", &Mesg[3]);
will print the message
lo, world
Corrected - thanks Mark for spotting that deliberate error to test who was awake :-)
Regards, Andrew
Mark
PostPosted: Mon Jun 19, 2006 7:53 am     Reply with quote
        char Mesg[20];
the line
      printf("%c", *Mesg[5])
the line
lo, world
I think you meant to write
