16c505 portb pullups
dan king
PostPosted: Thu Jun 15, 2006 8:10 am     Reply with quote
I'm trying to disable the port b pullups for the 16c505 using the pcb compiler (ver. 3.184) and the macro for setting the OPTION bits. For whatever reason the pullups are remaining enabled and I'm not sure why, any assistance would be appreciated.
#include <16c505.h>
//#include <16f877.h>         //16f877
//#fuses HS,NOWDT,PUT         //for 16f877
//#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,errors)         //was C6 and 9600 baud
#fuses INTRC,NOWDT,CLKOUT      // intRC = 4Mhz internal clock
// Constants and variables
#byte PORTB = 6
#byte PORTC = 7
#bit unload = PORTB.0
#bit load = PORTB.1
#bit data = PORTB.2
int      result;
int      loop;
int      load_command = 26;
int      unload_command = 44;
int      nothing = 0;
// General prototypes //
// local prototypes
void tx_data(int);
//   MACRO
#define set_options(value)   {#ASM         \
                              MOVLW  value \
                              OPTION       \
                              #ENDASM}
void main(){
set_options(0b11000010);
      //bit 7 = enable wakeup on change for rb0,1,3,4 = 0.    1 = disabled
      //bit 6 = enable weak pullups on rb0,1,3,4 = 0         1 = disabled
      //bit 5 = timer0 clk source select bit, 0= internal clk   1 = external source
      //bit 4 = timer0 source edge, 0 = external lo to hi      1 = external hi to lo
      //bit 3 = prescaler assignment, 0 = timer0            1 = WDT
      //bits 2- 0 = prescaler
      //000 = 1:2
      //001 = 1:4
      //010 = 1:8
      //100 = 1:16
      //101 = 1:32
      //110 = 1:64
      //111 = 1:128
//configure peripherals
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8);
   set_tris_b(0b00000011);
   result = 0;
// loop until reset
   while(1){
      if (load){
         tx_data(load_command);
      else if (unload){
         tx_data(unload_command);
      delay_ms(4);
void tx_data(int command)
      data = 1;                     //start bit
      delay_ms(2);
      for (loop=0; loop<6; loop++){      //data payload = 6 bits
         data = (command & 0b00100000);
         command = command << 1;
         delay_ms(2);
      data = 1;                     //stop bit
      delay_ms(2);
      data = 0;
Thanks,
Dan
epideath
PostPosted: Thu Jun 15, 2006 9:49 am     Reply with quote
check this topic out it might help
http://www.ccsinfo.com/forum/viewtopic.php?t=17154&highlight=port++pullup
dan king
PostPosted: Thu Jun 15, 2006 10:07 am     Reply with quote
Thanks but not only is PORT_B_PULLUPS(FALSE) not available for the 16c505 but the INTCON reg is not used to clear the PU's. It's supposed to accomplished through writing to the OPTION parameter. For whatever reason I can't get it to work properly. For a quick fix, I simply changed the logic I'm polling for and rewired the switch to pull the port low. I would like to know a fix for the future.
Thanks for the input though.
Dan
PostPosted: Thu Jun 15, 2006 11:36 am     Reply with quote
I would never do this. I would fix the problem.
The option register controls the pullups. If they're not being turned
off, the implication is that the option register is being re-programmed
later in the program, perhaps by a CCS function. A quick look at
the .LST file would tell if this is happening.
I don't have the PCB compiler, so I can't test this, but the Timer 0
prescaler is controlled by the OPTION register in the 16c505.
In your code below, you are setting up Timer0 after you call the
set_options() macro. I suspect that setup_timer_0() is the cause
of the problem. Try moving the set_options() line so it's below
the setup_timer_0() line. Also check the .LST file.
result = 0;
Change it to this:
result = 0;
dan king
PostPosted: Thu Jun 15, 2006 12:19 pm     Reply with quote
Thanks for the suggestion, I'll try that straight away. I never thought of the setup_timer affecting the option reg so we'll see.
FWIW:
The quick fix is still for bench testing so I can continue working until I find the solution.
If the culprit isn't the setup routine, I'll review the .lst. I just wanted to check if anyone had experienced this before I dug into the list.
I'll let you know how I make out.
Rgds,
Dan
dan king
PostPosted: Thu Jun 15, 2006 12:27 pm     Reply with quote
Yup, that did it !!! Thanks a bunch.
Rgds,
Dan
