Why in this code the array index "next_in" increments automaticaly when there is an interrupt.
Why when I try to fill the arrays buffer and buffer_temp they got dferent data?
#int_rda
void rx_serial_data()
byte t;
char ch;
count +=1;
ch=getc();
buffer[next_in] =ch; // get the data(single character) from serial port
buffer_temp[next_in]=ch;
t=next_in;
if (buffer[next_in]=0x0A)
++count_lf;
if (count_lf=2)
end_message=true;
next_in=(next_in+1) % BUFFER_SIZE;
if(next_in==next_out)
next_in=t; // Buffer full !!
Sending a "AT" command to a GSM modem, this is what I got using the ICD2
