Not correct delay with delay_ms
prayami
PostPosted: Wed Jun 07, 2006 3:51 pm     Reply with quote
Hi...
I am using 18F24J10, "CCS PCH C Compiler, Version 3.249" and
MPLAB IDE version 7.4 .
I am running the following simple program using software PLL. But
delay_ms is not correct. As my delay_ms(100) but the pulses are
remain high and low every time for 400ms.
I am using 10Mhz crystal with software PLL enabled.
If I do not use PLL and just work for 10Mhz then it is correct. I tried
changing different #fuses but no progress.
Thanks..in advance....
#include <18F24J10.h>
#fuses PRIMARY, H4_SW,NOSTVREN,PROTECT,NOFCMEN,NOFCMEN,NOIESO, NOWDT
#use delay(clock=40000000)
//Below work correct for 10Mhz
//#fuses NOWDT,HS,NOSTVREN,PROTECT,NOFCMEN,NOFCMEN,NOIESO
//#use delay(clock=10000000)
void Init_Setting()
  //setup_oscillator(OSC_STATE_EXT_RUNNING, OSC_NORMAL);
  delay_ms(10);
  set_tris_a(0xFF);
  set_tris_c(0x00);
  set_tris_b(0x00);
  delay_ms(10);
}//Init_Setting
 Init_Setting();
  while(TRUE) {
  output_high(PIN_B5);
  output_low(PIN_B5);
  }//while(TRUE)
}//main
treitmey
PostPosted: Wed Jun 07, 2006 4:14 pm     Reply with quote
If your time is 4 times too long it could be that your clock is 4 times too slow.
What I mean is your PLL isn't working. Did you know that you have to power cycle the PIC to get the PLL to work?
prayami
PostPosted: Wed Jun 07, 2006 4:35 pm     Reply with quote
Thanks...for reply....
I have set the thing in the configuration bits for PLL. Which is there in
#fuses .
I tried to turn the power off and stay for a while more than a minute and then ON again to reset but no difference.
I can't understand, why PLL is not working.....
Mark
PostPosted: Wed Jun 07, 2006 7:10 pm     Reply with quote
If it is a software controlled PLL then you have to turn it on. The datasheet says to set the PLLEN bit in the OSCTUNE register.
#byte OSCTUNE = 0xF9B
void Init_Setting()
  OSCTUNE = 0x40;
  delay_ms(10);
  set_tris_a(0xFF);
  set_tris_c(0x00);
  set_tris_b(0x00);
  delay_ms(10);
}//Init_Setting
 Init_Setting();
  while(TRUE) {
  output_low(PIN_B5);
  }//while(TRUE)
}//main
PostPosted: Wed Jun 07, 2006 7:16 pm     Reply with quote
The 18F24J10 data sheet says in section 2.4 that:
The PLL is enabled by setting the PLLEN in the OSCTUNE register.
However, the data sheet doesn't give the address of the OSCTUNE
register. So if you look in the P18F24J10.inc file, which is in this folder,
c:\Program Files\Microchip\MPASM Suite, then you find the address
is 0xF9B. Then you can set the PLLEN bit with this code:
#bit PLLEN = OSCTUNE.6
PLLEN = 1;    // Enable PLL
prayami
PostPosted: Wed Jun 07, 2006 7:22 pm     Reply with quote
Thats exellent Mark and PCM programmer. Thank you very much.
That works ...
I didn't know that for software controlled PLL require to enable PLL
like this in the program. I thought that, it is all included in the
configuration bits. As first time I come accross this kind of thing.
I was worried that address of OSCTUNE is not there in datasheet but
PCM programmer clear the doubt.
Thanks again....
Mark
PostPosted: Wed Jun 07, 2006 8:33 pm     Reply with quote
That's where I had to find it Smile
Mark
PostPosted: Wed Jun 07, 2006 8:34 pm     Reply with quote
That works ...
Thanks again....
I've never used that PIC either. However you mentioned "software PLL" so I read the datasheet to answer your question. Point, read the datasheet!
