charles Guest
| read_program_memory |
Posted: Wed Jun 07, 2006 8:08 pm |
Hi, I was wondering if it was a fastest way to read the program memory than the function read_program_memory, that is pretty slow.
Any pieces of information would be really helpful,
Thanks,
Charles. |
Mark
Posted: Wed Jun 07, 2006 8:38 pm |
| Read the datasheet. It tells you how to read program memory. |
Posted: Thu Jun 08, 2006 2:48 am |
Unfortunately, it won't be much if any faster.
The architecture of the PIC, does not allow direct 'read' access to it's memory. Hence doing this, involves setting up the pointer registers, and then accessing the data through a seperate register.
If you only need to access single locations, then this can be done more efficiently using the 'read_program_eeprom' function, which just performs the basic read at one address. The 'read_program_memory' function is designed to fetch 'blocks', and therefore has the overhead associated with accessing a data array to put the results into.
If you look at the code generated:
.................... test=read_program_eeprom(0x000100L);
.................... test=read_program_eeprom(address);
0DC6: MOVFF 2D,FF8
0DCA: MOVFF 2C,FF7
0DCE: MOVFF 2B,FF6 //transfer 'address' into the target registers
0DD2: TBLRD*+
0DD4: MOVF FF5,W
0DD6: TBLRD*
0DD8: MOVFF FF5,03
0DDC: CLRF FF8 //Move the data
0DDE: MOVWF 29
0DE0: MOVFF 03,2A //Store it into the result
And compare with the data sheet listing to do the same job:
EXAMPLE 6-1: READING A FLASH PROGRAM MEMORY WORD
MOVLW CODE_ADDR_UPPER ; Load TBLPTR with the base
MOVWF TBLPTRU ; address of the word
MOVLW CODE_ADDR_HIGH
MOVWF TBLPTRH
MOVLW CODE_ADDR_LOW
MOVWF TBLPTRL
READ_WORD
TBLRD*+ ; read into TABLAT and increment
MOVF TABLAT, W ; get data
MOVWF WORD_EVEN
MOVF WORD_ODD
The code is basically the same (except the compiler takes advantage of the single instruction moves offered on the larger PICs...).
charles` Guest
Posted: Thu Jun 08, 2006 12:18 pm |
Thank you very much for you help, i'll see what I can do.
-Charles. |
