Processing data from a RF module
DanX
PostPosted: Tue Jun 06, 2006 3:10 pm     Reply with quote
Whenever the transmitter is not transmitting, I get alot of garbage from my RX module. I'm sending an ascii message and it looks like this
UUU + (manchester encoded byte or 16bit)+UUU.
Is using Kbhit to poll for incoming serial data a good idea in this case? I tried it and it seems to freeze up my pic.
I'm trying to intercept my ascii message, parse it and decode the manchester encoded byte.
danX
PostPosted: Tue Jun 06, 2006 3:15 pm     Reply with quote
the thing making it hard is all the garbage characters going into the pic. THe pic seems overwhelm or something.
Right now i'm just trying to see if I can intercept the message and prints it to the screen. No decoding is done.
#include <16F88.h>
#device adc=8
#fuses XT,NOWDT,PROTECT,NOBROWNOUT,PUT,NOMCLR
#use delay (clock=4000000)
#use rs232(baud=14400, xmit=PIN_B5, rcv=PIN_B2)
#define uint8 char
#define uint16 long
uint16 man_encode(uint8 unenc);
uint8 man_decode(uint16 enc);
char string[20];
int receive_error=0;
main()
uint16 encoded=0;
uint8 decoded=0;
      if(kbhit()&& (getc()=='U'))
        gets(string);
      printf(string);
      output_high(PIN_B4);
      output_low(PIN_B4);
uint16 man_encode(uint8 unenc) {
   uint8 odd_byte,even_byte,temp;
   odd_byte=unenc&0xAA;
   temp=(~unenc&0xAA)>>1;
   odd_byte=odd_byte|temp;
   even_byte=unenc&0x55;
   temp=(~unenc&0x55)<<1;
   even_byte=even_byte|temp;
   return((uint16)odd_byte<<8)|even_byte;
uint8 man_decode(uint16 enc) {
   odd_byte=(uint8)(enc>>8);
   if((odd_byte&0xAA)^((~odd_byte&0x55)<<1)) {
      receive_error=1;
      return(0);
   } else odd_byte&=0xAA;
   even_byte=(uint8)enc;
   if((even_byte&0x55)^((~even_byte&0xAA)>>1)) {
      receive_error=1;
      return(0);
   } else even_byte&=0x55;
   receive_error=0;
   return(odd_byte|even_byte);
DanX
PostPosted: Tue Jun 06, 2006 3:17 pm     Reply with quote
My message
does have a '\r' at the end.
newguy
PostPosted: Tue Jun 06, 2006 3:23 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=23953
rnielsen
PostPosted: Tue Jun 06, 2006 4:17 pm     Reply with quote
Have you thought about using the RDA interrupt instead of trying to poll for characters inside of main()? That's what the hardware's there for.
DANX
PostPosted: Tue Jun 06, 2006 4:54 pm     Reply with quote
"forum/viewtopic.php?t=23953"
how can this code work without using manchester encoding? Maybe for expensive modules that doesn't require DC balance?
The module that i'm using require DC balance signal
newguy
PostPosted: Tue Jun 06, 2006 5:07 pm     Reply with quote
Try it first. If it doesn't work, then do a pseudo-manchester type of transmission by inserting "U" between each character you send. Discard the "U"s in the receiver.
Long story short: don't try to reinvent the wheel.
Humberto
PostPosted: Tue Jun 06, 2006 5:14 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=23886&highlight=manchester
http://www.ccsinfo.com/forum/viewtopic.php?t=24807&highlight=manchester
http://www.ccsinfo.com/forum/viewtopic.php?t=19141&highlight=manchester
http://www.ccsinfo.com/forum/viewtopic.php?t=27090&highlight=
Humberto
