pic18f4585
andreluizeng
View user's profile Send private message Send e-mail MSN Messenger
pic18f4585
PostPosted: Mon Jun 05, 2006 1:05 pm     Reply with quote
hi people...
im changing some code to work on 18f4585 (that was 16f877) and i sent some bytes to be port addresses..
#byte PORTA = 0x05
#byte PORTB = 0x06 .... etc..
how can i do that on 18f4585.. the address are 12bits long
PORTA = 0xf80
please.. help me.
regards..
Andre
PostPosted: Mon Jun 05, 2006 1:09 pm     Reply with quote
Do it in the same way. See this post for an example with the 18F452:
http://www.ccsinfo.com/forum/viewtopic.php?t=27181
andreluizeng
PostPosted: Mon Jun 05, 2006 1:13 pm     Reply with quote
pcm
i did that, but i thought that was wrong.. because help docs says that #byte is 8 bit long.. but.. anyway..
thanks for the help.
regards.
Andre
PostPosted: Mon Jun 05, 2006 2:23 pm     Reply with quote
The #byte declaration, declares a 8 bit variable _at_ a location, that can be anywhere in RAM. 'PortA', is still only 8 bits long itself, it is the address that has got larger. :-)
