MMC CODE ERROR
deltatech
MMC CODE ERROR
PostPosted: Fri Jun 02, 2006 6:33 pm     Reply with quote
HI I am Using a CCS Prototyping board with a MMC Card Reader So the Hardware should be OK well its made by CCS!
I have tried two different versions of the MMC CODE fromt this forum both of them are not working . The Error for both is same if the card is in or out . The Card is woks fine in a nokia phone also .
So it must be the code Any help wpuld be appriciated .
This code gives the Following error
06/03/2006 01:15:46.015 --> Start\0A
\0A \0D
\0A06/03/2006 01:15:46.046 --> Write Error \0D
http://www.ccsinfo.com/forum/viewtopic.php?t=23183&start=15
#include "F:\Program Files\PICC\Project\MMC-Code\MMC-WORK\CCS-MMC.h"
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
//#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)
#use fast_io(C)
// TEST : using the mmc in write and read mode.
// Based on http://www.ccsinfo.com/forum/viewtopic.php?t=23183
//#fuses HS,NOWDT,NOPUT,NOLVP,NOBROWNOUT,NOCPD,NOWRT
//#use rs232(baud=9600, xmit=PIN_E1, rcv=PIN_E0,ERRORS)
//#use fast_io(B)
//#use fast_io(C)
#use fast_io(C)
#use fast_io(D)
// For the PIC 18F4520 see manual on page 68/426
#byte SSPBUF = 0xFC9
#byte SSPCON = 0xFC6
#byte SSPSTAT = 0xFC7
#bit  BF = SSPSTAT.0
#bit SMP = SSPSTAT.7
#bit CKE = SSPSTAT.6
#bit CKP = SSPCON.4
#bit SSPM1 = SSPCON.1
#bit SSPEN = SSPCON.5
#byte PORTC = 0xF94
#byte PORTD = 0xF95
#bit CS = PORTD.3
On the Eternet Prototyping Board PIC to MMC PIN Connection
#bit CS = PORTD.3
#bit DIN = PORTC.5
#bit D0 = PORTC.4
#bit CLK = PORTC.3
// Command codes
#define MMC_CMD(x)         (0x40 + x)    // A command always starts with the same two start bits.
#define GO_IDLE_STATE     MMC_CMD(0)    // Reset card to Idle State
#define SEND_OP_COND      MMC_CMD(1)    // Activates the card's initialization process.
#define SEND_STATUS       MMC_CMD(13)   // Asks the card to send its status register
#define READ_SINGLE_BLOCK MMC_CMD(17)   // Reads a block of the size selected with SET_BLOCKLEN
#define WRITE_BLOCK       MMC_CMD(24)   // Writes a block of the size selected with SET_BLOCKLEN
#define MMC_TIME_OUT      0xFF          // Just a long time out value
#define TIMER_EXPIRED     0
// This is the same as the CCS spi_read() function.
char SPI(char d)
  SSPBUF=d;
  while (!BF);
  return SSPBUF;
// Send a command with parameters to the MultiMediaCard
int8 Command(int8 Cmd, int8 Param1, int8 Param2, int8 Param3, int8 Param4)
  int8 Response;
  int8 TimeOutCounter;
  // Allow at least 8 dummy clocks between commands
  spi_read(0xFF);   // note that the first bit is undefined when card is busy (high impedance state)
  // check for the card not being in busy state.
  TimeOutCounter = MMC_TIME_OUT;
  do
    Response = spi_read(0xFF);
  while ((Response != 0xFF) && (--TimeOutCounter != TIMER_EXPIRED));
  if (TimeOutCounter == TIMER_EXPIRED)
    puts("Time out; card busy.\r\n");
    return 0xFF;
  // Send command to the card
  spi_write(Cmd);         // Command
  spi_write(Param1);      // Parameter 1
  spi_write(Param2);      // Parameter 2
  spi_write(Param3);      // Parameter 3
  spi_write(Param4);        // Parameter 4
  spi_write(0x95);        // CRC (including End Bit)
                          // Hard coded the CRC to 0x95 because CRC is always
                          // don't care except for CMD0 which uses 0x95.
  // Wait for response
  do
  while ((Response == 0xFF) && (--TimeOutCounter != TIMER_EXPIRED));
  return Response;
char MMC_Init()
  char i;
  // Init SPI
  SMP=0; CKE=0; CKP=1; SSPM1=1; SSPEN=1; //SSPM0=1;
  CS=1;      // MMC-Disabled
  // MMC in SPI Mode -- start and Reset.
  for(i=0; i < 10; i++) SPI(0xFF);            // 10*8=80 clocks
  CS=0;                                       // MMC-Enabled
  // CMD0
  if (Command(GO_IDLE_STATE, 0,0,0,0) != 1)
    goto Error; // Reset
st:
  // CMD1
  if (Command(SEND_OP_COND, 0,0,0,0) != 0)
    goto st ;   // CMD1
  return 1;
Error:
  return 0;
  int16 i;
  setup_adc_ports(NO_ANALOGS);
  // PIC 18F code
//  set_tris_c(0b01111011);       // sdo=rc7(pin26)-0, CS=rc2(pin17)-0.
 // set_tris_b(0b00000000);       // sck=rb1(pin34)-0, sdi=rb0(pin33)-I
//PIC 18F4520
set_tris_d(0b00000000);
  set_tris_c(0b00010000);
  puts("Start\n\r");
  if(MMC_Init())
    puts("MMC ON - Init OK\n\r");       // MMC Init OK
  // Write block
  if (Command(WRITE_BLOCK, 0,0,2,0) != 0)
    puts("Write error in begin of write"); // Write in 512 Byte-Mode
    SPI(0xFF);              // Wait a minimum of 8 clock pulses
    SPI(0xFE);              // Write the Start Block Token (0xFE)
    SPI("Begin\n\r");       // 7 characters
    for(i=0; i < 500; i++)  // Was 512, but used 12 for text
      SPI('M');
    SPI("\n\rEnd");         // 5 characters
    SPI(0xFF);              // Write the 16-bit CRC at the end (don't cares)
    SPI(0xFF);
    i = SPI(0xFF);          // Get data response token
    i &= 0b00011111;
    if (i != 0b00000101)
      i = Command(SEND_STATUS, 0,0,0,0);
      printf("Write Error in end of write (status: 0x%X)\n", i);
    while(SPI(0xFF) != 0xFF)
      ; // Wait for end of Busy condition
  // Read in 512 Byte-Mode
  if (Command(READ_SINGLE_BLOCK, 0,0,2,0) !=0)
    puts("Read Error ");
    while(SPI(0xFF) != 0xFE);
    for(i=0; i < 512; i++)
      putc(SPI(0xFF));       // Send data
    SPI(0xFF);     // Send two bytes of 0xFF at the end
    SPI(0xFF);
  while(1);       // The program stops here.
With The Other version i get the following error
06/03/2006 01:27:19.750 --> Start\0A
\0A \0D
\0A06/03/2006 01:27:19.750 --> Time out; card busy.\0D \0A\0D
\0A06/03/2006 01:27:19.781 --> Time out; card busy.\0D \0A\0D
\0A06/03/2006 01:27:19.796 --> Write error in begin of write\0D \0A06/03/2006 01:27:19.843 --> Time out; card busy.\0D \0A\0D
\0A06/03/2006 01:27:19.875 --> Read Error \0D
#use fast_io(C)
//#use fast_io(B)
//#use fast_io(C)
#use fast_io(C)
#use fast_io(D)
#bit  BF = SSPSTAT.0
#bit CKP = SSPCON.4
#byte PORTC = 0xF94
#byte PORTD = 0xF95
#bit CS = PORTD.3
#bit CS = PORTD.3
#bit DIN = PORTC.5
#bit D0 = PORTC.4
#bit CLK = PORTC.3
// Command codes
char SPI(char d)
  SSPBUF=d;
  while (!BF);
  return SSPBUF;
  int8 Response;
  do
    return 0xFF;
  do
  return Response;
char MMC_Init()
  char i;
  // Init SPI
  // CMD0
st:
  // CMD1
    goto st ;   // CMD1
  return 1;
Error:
  return 0;
  int16 i;
  // PIC 18F code
//PIC 18F4520
  puts("Start\n\r");
  if(MMC_Init())
  // Write block
      SPI('M');
    SPI(0xFF);
    i &= 0b00011111;
    SPI(0xFF);
PostPosted: Sat Jun 03, 2006 12:39 am     Reply with quote
I looked up a couple of the addresses in the following list,
and they're wrong.
#bit BF = SSPSTAT.0
#bit CKP = SSPCON.4
#byte PORTC = 0xF94
#byte PORTD = 0xF95
#bit CS = PORTD.3
You have this:
#byte PORTC = 0xF94
#byte PORTD = 0xF95
In fact, those are the TRIS register addresses.
The addresses of PORTC and PORTD are 0xF82 and 0xF83, respectively.
Details are important. See this section in the 18F4520 data sheet:
TABLE 5-1: SPECIAL FUNCTION REGISTER MAP FOR PIC18F2420/2520/4420/4520 DEVICES
I didn't check the rest of the list. You need to check it.
deltatech
MMC CODE ERROR
PostPosted: Sat Jun 03, 2006 7:44 am     Reply with quote
Thanks PCMPROGRAMMER For your Advice I have changed Port C and Port D address . But I still get the same error.
06/03/2006 14:41:23.265 --> Start\0A
\0A \0D
\0A06/03/2006 14:41:23.281 --> Time out; card busy.\0D
\0A\0D
\0A06/03/2006 14:41:23.328 --> Time out; card busy.\0D
\0A\0D
\0A06/03/2006 14:41:23.343 --> Write error in begin of write\0D
\0A06/03/2006 14:41:23.390 --> Time out; card busy.\0D
\0A\0D
\0A06/03/2006 14:41:23.421 --> Read Error \0D
I have noticed one thing on Page 63 Datasheet 18f4420
SSPCON is listed as [b]SSPCON1 [/b] . However if i change this to SSPCON the compliler doesnt like it .
#use fast_io(C)
//#use fast_io(B)
//#use fast_io(C)
#use fast_io(C)
#use fast_io(D)
#bit  BF = SSPSTAT.0
#bit CKP = SSPCON.4
#byte PORTC = 0xF82
#byte PORTD = 0xF83
#bit CS = PORTD.3
#bit CS = PORTD.3
#bit DIN = PORTC.5
#bit D0 = PORTC.4
#bit CLK = PORTC.3
// Command codes
char SPI(char d)
  SSPBUF=d;
  while (!BF);
  return SSPBUF;
  int8 Response;
  do
    return 0xFF;
  do
  return Response;
char MMC_Init()
  char i;
  // Init SPI
  // CMD0
st:
  // CMD1
    goto st ;   // CMD1
  return 1;
Error:
  return 0;
  int16 i;
  // PIC 18F code
//PIC 18F4520
  puts("Start\n\r");
  if(MMC_Init())
  // Write block
      SPI('M');
    SPI(0xFF);
    i &= 0b00011111;
    SPI(0xFF);
PostPosted: Sat Jun 03, 2006 8:13 am     Reply with quote
A few days ago in thread http://www.ccsinfo.com/forum/viewtopic.php?t=27180 you wrote
I am Using CCS Ethernet Prototyping board
Which to my understanding contains an 18F4520
Then in a Private email you send me
#include <18F4620.h>
The 4420 and 4520 are described in the same datasheet, but the 4620 is from another family.
Can please check out the processor type on your hardware, mention it to us and then stick to it?
Development is in the small details...
deltatech
MMC CODE ERROR
PostPosted: Sat Jun 03, 2006 9:16 am     Reply with quote
HI Yes on the Board it say 18F4520 . But when i complile it the ICD-U40 comes up whith a message the Processer is 18F4620 .
And I selected 18F4620 . and it compiles . So i dont know whats going on . They may have changed the PIC in manufacturing .
deltatech
MMc Code Error
PostPosted: Sat Jun 03, 2006 9:22 am     Reply with quote
Infact I have checked it on the PIC it says 18F4620 . so they have changed the chip in Manufacture .
PostPosted: Sat Jun 03, 2006 6:12 pm     Reply with quote
You are using my Command() function as posted in the thread http://www.ccsinfo.com/forum/viewtopic.php?p=53447. This function is working in my own program but when I posted it I never tried it in combination with the other routines from that thread. Bart said about this:
PS : ckielstra : can't manage to let it work with yours. I think something is missing. Thanks anyway for your help.
So it isn't a great surprise this function isn't working for you either.
I could spend some time trying to figure out what the error is, but I don't have a test system at home and to be frank I don't want to. The program as given here has many flaws and is not easy to port to other PIC processors (look at how much time you spend). The biggest flaw is setting the CS line only once and then never releasing it, according to the MMC specifications the CS line should be toggled between all commands.
I recommend you try another MMC driver, for example:
- The CCS supplied driver mmc_spi.c in the drivers directory of your compiler.
- A FAT16 file system in the Code Library: http://www.ccsinfo.com/forum/viewtopic.php?t=21721
deltatech
PostPosted: Sun Jun 04, 2006 7:43 am     Reply with quote
Thanks ckeistra for your advice i will look try the ccs mmc driver . and see how it goes .
