fabsys Guest
poblem with rda interupt ... |
Posted: Fri Jun 02, 2006 8:34 pm |
hi all,
i've a probleme with a rda interupt
#include <16F876.h>
#use delay (clock=20000000)
#fuses HS, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,parity=n,bits=8)
#int_global
char a;
#int_rda
void int_reception(void)
static char c;
// Read char from USART.
c = getc();
// Send char back to the PC.
putc(c);
SET_TRIS_a(0b00000010);
SET_TRIS_a(0);
set_tris_c(0b10000000);
// PORT_C=0x00;
// Enable the USART receive interrupt.
enable_interrupts(INT_RDA);
printf("start");
for(;;)
if (a)
OUTPUT_HIGH(PIN_A0);
a=0;
OUTPUT_LOW(PIN_A0);
a=1;
if (INPUT(PIN_B1))
OUTPUT_HIGH(PIN_B2);
OUTPUT_LOW(PIN_B2);
if someone can help me ..... thx ;) |
Posted: Sat Jun 03, 2006 6:34 am |
thx PCM programmer for ur help
it's ok |
