ATOI() Won't Convert Hex To Int8
DonWare
PostPosted: Fri Jun 02, 2006 3:28 pm     Reply with quote
I really did look around here for a solution to this
problem before I posted but...
If I run this code I get X=0.
If I use onle decimal characters it works OK.
int1 temp;
char tmp_buff[15];
int8 x;
tmp_buff[0]='F';
tmp_buff[1]=0;
x=atoi(tmp_buff);
What am I doing wrong ?
The goal is to convert two incoming ASCII checksum characters into int8.
An alternate method idea is welcomed.
Thanks in advance.
Don
Shocked
rwyoung
PostPosted: Fri Jun 02, 2006 3:31 pm     Reply with quote
From good, ole Unix man pages:
The atoi(), atol(), strtol(), and strtoul() functions are used to convert a
character string pointed to by the nptr parameter to an integer having a
specified data type. The atoi() and atol() functions convert a character
string containing decimal integer constants, but the strtol() and strtoul()
functions can convert a character string containing a integer constant in
octal, decimal, hexadecimal, or a base specified by the base parameter.
Check to see if strtol() and strtoul() exist in the CCS compiler documentation. Otherwise consider writing your own.
Rob Young
DonWare
ccs manual
PostPosted: Fri Jun 02, 2006 3:36 pm     Reply with quote
The ccs manual says "Accepts both decimal and hexadecimal argument"
I entered the example form the manual and it worked ok - except for hex input.
Thanks.
PostPosted: Fri Jun 02, 2006 3:45 pm     Reply with quote
You're giving atoi a string of "F".
How does atoi know that this is a hex digit ?
Look in the source code for atoi(), which is in stdlib.h
(Look it c:\Program Files\PICC\drivers)
It's looking for "0x" to be in front of the hex string:
      // Check for hex number
      if (c == '0' && (s[index] == 'x' || s[index] == 'X'))
So you need to add two bytes to your tmpbuff to make
it hold "0xF".
DonWare
Tried
PostPosted: Fri Jun 02, 2006 3:49 pm     Reply with quote
I tried 0x and had no luck.
What I've decided to do is use isalpha() or isdigit() and go from there for each character.
Thanks.
DonWare
My Bad
PostPosted: Fri Jun 02, 2006 3:52 pm     Reply with quote
I tried 0X again and it worked. Who knows what I did wrong before.
I didn't know code was available for the built in functions.
Thanks alot !!!
