understanding signed long
roby
PostPosted: Wed May 31, 2006 1:01 pm     Reply with quote
I would like to know how many bits a signed long variable occupies and if it is possible to transfer that information through I2C bus.
My code is:
// master
signed long count
i2c_write (make8 (count,0))
i2c_write (make8 (count.1))
// slave
signed long counter
int8 counter_high, counter_low
counter_low=i2c_read()
counter_high=i2c_read()
counter=make16(counter_high, counter_low)
Thank you
PostPosted: Wed May 31, 2006 4:04 pm     Reply with quote
Download the CCS compiler manual. Go to page 86 in the Acrobat reader.
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
There is a chart that tells you the size of a 'long' variable is in CCS.
The size is the same for a 'signed' or unsigned long.
roby
the essential question
PostPosted: Thu Jun 01, 2006 12:43 am     Reply with quote
I have read the manual, but there is a thing I can't understand
The information I need is if I can use make8 and make16 with signed long and not loose the sign.
I do not know if I explain the problem
Thank you
Humberto
PostPosted: Thu Jun 01, 2006 9:30 am     Reply with quote
In CCS unless it indicates the opposite in explicit form, an int by default is an unsigned integer.
Anyway if you are using signed int, the MSBit of the MSByte should keep the sign.
Humberto
Re: the essential question
PostPosted: Thu Jun 01, 2006 10:09 am     Reply with quote
Thank you
Nothing will be lost. The function 'make 8', just returns the byte (whichever one you select), and couldn't care at all whether the top bit is a sign or not. Similarly, make16, just puts two bytes back together.
If you have two bytes:
LSB   MSB
0x77 0x80
And you assemble together into a variable, you have defined as unsigned int16, then this variable will have the value '32887'. Put the two bytes into a variable you have designated as 'signed', and it will have the value
-32649.
You can play with this, and get a better understanding of it all (hopefully... :-), by using a union. If you declare:
[code]
union types {
int16 word;
signed int16 sword;
int8 b[2];
} converter;
[code]
Then set (say) converter.sword = -1000, you can access the two bytes seperately, as converter.b[0], and converter.b[1], which will be 0x18, and 0xFC (this basically does the same as 'make8'). You can also access 'converter.word', which will equal 64536. The same data, has different meanings, according to how you 'look' at it. All the 'signed' declaration does, is say to the compiler, to use the top bit as a 'sign' bit. It does nothing tochange the actual naure of the values.
Using the union, can also be done the other way, so if you write values into 'converter.b[0]', and 'converter.b[1]', you can then look at what this pair of bytes represent, when treated as a signed, or unsigned value (using converter.sword, and converter.word).
