cubah Guest
Function Pointer PIC18 CCS bug? |
Posted: Thu Jun 01, 2006 2:15 am |
Hallo All
I have sample code which is not working is I'm using function pointer to turn-on red led (LED is turned-on when pin_A0=0)
PS.
I did the same way as shows CCS example "ex_qsort.c" in /examples directory!
#include <18F2550.h>
#byte LATA = 0xF89
#byte TRISA = 0xF92
//#device *=16 // 16 bit pointers
// *** ROM program locations *** //
#build( reset=0x0A00, interrupt=0x0A00+8)
#org 0x0000, 0x0A00-1 { } // bootloader
// CPU clock (config determined in bootloader)
#define FREQ_CPU 48000000 // 48Mhz
#use delay ( CLOCK = FREQ_CPU, RESTART_WDT )
#define LED_RED PIN_A0
#define RED_ON output_low( LED_RED )
#define RED_OFF output_high( LED_RED )
typedef void (*HandlerFun) ();
void hRedOn() {RED_ON;}
void hRedOff() {RED_OFF;}
void main (void)
HandlerFun hFun;
delay_ms( 10 ); // need to wait for PLL?
LATA = 0xff; // all leds off!
TRISA = 0x0; // all outputs
delay_ms( 100 );
hRedOn(); // force CCS to this link function
hRedOff();
hFun = hRedOn;
(*hFun)(); // like in example "ex_sort.c" but here not
working!!!
//goto_address(hFun);// not working also!
//hRedOn(); // WORKING!!!
restart_wdt();
return;
Ktos zna ten bug? |
Posted: Thu Jun 01, 2006 4:45 am |
This is _C_, not C++. There is a very fundamental difference in the way that 'void' is understood.
Seperately though, there is a probable problem with trying to generate addresses for the internal 'functions' output_high, and output_low. These are almost certainly macro definitions, _not_ actual functions.
If you want to use these through pointer accesses, then put each into a wrapper function, and generate the addresses of these. If you look at the 'call tree' for a program, you will see that there is no call ever occuring to these names, making it certain that they are macros, not actual funstions.
