pasini
Joined: 12 Dec 2005 Posts: 50 Location: Curitiba - Brazil
USB driver does not load |
Posted: Wed May 31, 2006 5:36 pm |
MPLAB 7.10 and CCS 3.325
I have a LOW-VOLTAGE PIC18LF4550 working at 3.3V and 16MHz.
I have a resistor connected to the USB 5V and pin RC6 to be the bus sense, and a 470nF capacitor at VUSB.
The problem is that when I connect the board to the computer USB nothing happens, WindowsXP does not recognize it. I do not hear the Windows beeping when USB device is connected.
I am trying to do a serial COM port to talk to the Hyperterminal, CDC (Communication Device Class) model, with the usbser.sys driver.
I find here at the forum a *.inf file with some descriptions that seams to be correct.
Is there something missing with my hardware ? And with the firmware ?
My code is:
#include <18F4550.h>
#device *=16
#device ADC=10
//configure a 16MHz crystal to operate at 48MHz
#fuses HS,NOWDT,NOPROTECT,NOLVP,NODEBUG, PLL4
#use delay(clock=16000000)
#include <defines.h>
#include <buzzer.h>
#include <lcd.h>
#include <pc.h>
#define __USB_PIC_PERIF__ 1
#define USB_CON_SENSE_PIN PIN_C6
#include <usb_cdc.h>
setup_psp(PSP_DISABLED);
usb_init();
while(!usb_cdc_connected());
printf(usb_cdc_putc,"Test USB");
Thanks in advance for any help,
Pasini |
Posted: Wed May 31, 2006 5:56 pm |
Quote: | #include <18F4550.h>
#device *=16
#device ADC=10
#use delay(clock=16000000) |
The CCS examples show the fuse as HSPLL, not HS. |
Posted: Mon Sep 25, 2006 2:23 pm |
hi.pasini
COULD YOU TELL ME YOUR PROBLEM HAS BEEN SOLVED?
I MEET THE SAME PROBLEM TOO, IS IT POSSIBLE TO SHARE YOUR ANSWER?
Tks. |
pasini
Posted: Mon Sep 25, 2006 7:12 pm |
Since the suggestion is only related to firmware, you should try to verify if it works by yourself
But I reply that the change to HSPLL instead of HS, solved my problem.
Good luck
Pasini |
Felipe Guest
Posted: Tue Dec 26, 2006 3:06 pm |
Hi Pasini,
I realized you are from curitiba, so...
Voce poderia me enviar ou me explicar o seu hardware para esse projeto? Porque eu já fiz as correções no firmware e continuo com o mesmo problema: o windows XP não faz nada quando eu plugo o circuito.
felipekitamura@yahoo.com.br |
